Base Timing
Old Sep 6, 2010 | 04:41 PM
Ford Breakdown's Avatar
Ford Breakdown
Base Timing
I know my '86 Ranger should have a base timing of 10 degrees BTC. I was wondering, is it necessary to disconnect any wiring from the distributor when checking this value with a timing light? Thanks; Haynes does not detail the procedure.
Old Sep 6, 2010 | 09:30 PM
wtroger's Avatar
wtroger
You disconnect the spout connector to set the 10 degree base timing. It is a plug in the wiring harness near the distributor.
Old Sep 8, 2010 | 04:07 AM
1949f1's Avatar
1949f1
on my 86 ranger, it was in the harness right were the heater hose comes out of the firewall area. i had to untape my harness to find it.
Old Sep 12, 2010 | 11:49 AM
G2IC_Wraith's Avatar
G2IC_Wraith
On my 88' 2.3L it was up by the battery/air box kind of low by the battery tray.
Old Sep 12, 2010 | 12:11 PM
tomw's Avatar
tomw
On an '85 2.3EFI it is hanging out of the wire loom between the driver side inner fender and the engine. A rectangular plug with a wire loop externally visible.
tom
