Code 332 and Exhaust leak
Old Feb 18, 2003 | 05:46 PM
mikej's Avatar
mikej
My 93 f150 with 302 recently started throwing a code 332 and giving a CEL after driving. The light does not come on while idleing. I have removed the EGR and cleaned it and it appears to function properly. I do however hear what sounds like an exhaust leak beneath the upper intake. Does this sound like it could be the EGR Tube causing both problems? Does thsi tube connect to the lower intake or does it route out the back of the engine compartment?
Thanks in advance,
mike
Old Feb 18, 2003 | 06:20 PM
Chas1234's Avatar
Chas1234
I think the leak you are looking for is the crossover that bolts to the back of the engine ..its the smog cross over that bolts to the cylender heads ..take a look at that
Old Feb 18, 2003 | 07:46 PM
mikej's Avatar
mikej
Thanks for the reply. I guess I should have been a little more specific as to what I had done so far in tracing. I have probed the entire engine compartment front to back, side to side with a medical stethoscope and have narrowed the sound to directly beneath the upper intake and along the same line that I loose sight of the egr tube. I have not removed the upper intake as of yet,. I have felt the length of the tube that I can reach and can not feel any obvious cracks. It does still have the cloth wrap on it so can not be completely certain. I have not gotten up the nerve to stick my hand under the upper intake with the engine running, yet though. If I disconnect the tube from the bottom of the egr valve it seems more flexible that I would expect it to be. I think that it has a flexible area that may be allowing the movement. I have no problems with removing the upper intake if need be, yet did not want to if it was not absolutely neccessary. Is there anything else under that location that would sound like an exhaust leak, get louder with acceleration and once the engine warms get less noticeable?
Old Feb 18, 2003 | 07:51 PM
Mattman1's Avatar
Mattman1
Hey, the egr tube although some what flexible is not reallt that flexible at all. If as you say it feels like it is too flexible it has probably rusted out or somehow else broke. Should be a cheap fix.
Old Feb 18, 2003 | 09:52 PM
steve83's Avatar
steve83
The EGR tube is the only thing there that would leak. It's screwed into the lower intake, which gets exhaust from one of the heads. Soak it with Liquid Wrench for 2-4 days before you want to pull it apart and have replacement intake gaskets on hand before you start. I think one of the upper intake (plenum) bolts is a Torx-drive, so look before you start.
Old Feb 19, 2003 | 07:29 AM
DoubleA's Avatar
DoubleA
I was getting a code 332 that turned out to be a vacuum leak. On my 300, the coffee can was in the EGR circuit and it rusted through. I chased the problem for a while before I checked the vacuum at the solenoid, there was only about 5" hg.
Check the vacuum going into the EGR control solenoid valve, make sure it is between 15-20" hg.
I just bypassed the can and no more codes.
Old Feb 19, 2003 | 07:57 AM
Mattman1's Avatar
Mattman1
still wouldn't explain the exhaust noise/leak.
Old Feb 19, 2003 | 01:24 PM
mikej's Avatar
mikej
Thanks for all the replies. I am hoping to get the opportunity this week to remove the upper intake to find that the $70 egr tube needs replacing. If I decided to drive it would it cause any internal damage to the engine with this leak?
Old Feb 19, 2003 | 07:04 PM
Mattman1's Avatar
Mattman1
No damage it is just an emissions item, and an anooyance with the noise. I have seen when they leak too close to wires or other meltables it can melt them.
Old Feb 19, 2003 | 07:47 PM
Diesel_Dummy _'s Avatar
Diesel_Dummy _
have you even looked at the exhaust manifold ?
the right side is known to crack on these trucks
mine was cracked in 3 places
Old Feb 19, 2003 | 09:04 PM
mikej's Avatar
mikej
Diesel_Dummy_
Thanks and as I noted above...
I have eyeballed everything as well. I am as positive as I can be without physically removing the upper intake and taking the egr tube off that that is the culprit. Would a leaking manifold throw a code 332? Or are you thinking that they could be seperate issues?
Old Feb 20, 2003 | 06:02 AM
Diesel_Dummy _
they all throw EGR codes after so many miles
Old Feb 20, 2003 | 04:04 PM
DoubleA's Avatar
DoubleA
I would say you have two problems, an exhaust leak in the egr tube and also a problem with the EGR, a leaking tube would only give a code if the EGR has positive feedback - where it sees if there is pressure at the exhaust side of the valve. Check a haynes to see the difference but I didn't think that year has it.
The EGR position sensor can be checked with an OHM meter, Haynes manual explains how to check and what pins to check.
It should have a consistant ohm reading from about 3500 at no vacuum to 400 at full vacuum if I remember my numbers right.
A code 332 is when there is a difference in what the computer wants for EGR position and what it really is.
Again, also check the vacuum where the line from the manifold hooks onto the EGR solenoid. if there is no vacuum the EGR doesn't move, that's what was wrong with mine, I didn't find out till hours of replacing sensor and screwing with the EGR solenoid.
UncleCracker302
May 3, 2013 04:03 AM
JCastellaw
Dec 23, 2008 05:39 PM
Samell
1983 - 2012 Ranger & B-Series
Mar 30, 2008 08:45 AM
brassy
Jun 11, 2006 11:59 AM
Keith460
Jan 15, 2001 01:35 PM
