Bronco II Ford Bronco II
push botton 4 wheel drive
Old Feb 18, 2003 | 04:55 PM
silvana's Avatar
silvana
Unhappy push botton 4 wheel drive
I have a 1987 Bronco, and I have problems with the touch drive.
The light of 4 x4 botton is on, and the light for Low range is flashing, and I don't want to drive in 4 wheel drive, I just want the normal transmition. How can I turn off the lights, and drive in 2 wheel drive? I shift it to neutral but nothing happen!!
Please, if you know the instruction, send me a email!
Thanks, and sorry my english!!:
Old Feb 18, 2003 | 08:22 PM
Ken00's Avatar
Ken00
Welcome to Ford Truck Enthusiasts BII Forum!!!
I can't help with your 4x4 problem but you could try using the search function to look for other post with similar problems.
Old Feb 18, 2003 | 10:21 PM
mrshorty's Avatar
mrshorty
the transfer case shift motors on these are known to get dirty and stuck. Sometimes just tapping the shift motor while someone else pushes the button will get it to loosen up and shift. You can also pull the motor off, take it apart, and clean it up and that will get it to work.
