Rear Drum Removal help
Old Sep 5, 2010 | 06:58 PM
78ford351m's Avatar
78ford351m
It appears I need to remove the rear axle? I have a F-250 dana 60. Just bought the rear disc kit. Just need some advice/help getting the drums off. I wasn't sure, but I removed the rear axle (8 bolts). Got that out and have been pounding about an hour. Keep pounding or am I missing something? Nice thing is I have the bed off so I can get from the rear.
Old Sep 5, 2010 | 07:28 PM
4x4 Bart's Avatar
4x4 Bart
You have to remove the two axle nuts that are in the center of the hub.
Old Sep 5, 2010 | 08:05 PM
78ford351m's Avatar
78ford351m
LOL. I'll have to look tomorrow then. The axle is pulled and it was getting dark. Sounds like I'm in the right direction.
Old Sep 6, 2010 | 10:29 AM
78ford351m's Avatar
78ford351m
Okay looked this morning and I do not see what you are saying. I have a dana 60. Are you sure they are the same?
Old Sep 6, 2010 | 10:59 AM
78ford351m's Avatar
78ford351m
Think I got it. Found this:
A Boy and his Jeep Dana 60/70 Rear Drums
says I need a 2 9/16" socket!!! Omg, talking about one expensive socket that I'll never use again LOL
Old Sep 6, 2010 | 11:15 AM
Rusty_Old_F250's Avatar
Rusty_Old_F250
There is another way, take a screwdriver and knock a little notch into the nut, just big enough to let the screwdriver grip it, and give it a good whack with a hammer, it should loosen it. You can spin it out by hand after that. Be careful where you make the notch, though, try to do it on the top edge of the nut, not on the side. When you put it back together, be sure you tighten those things good, you do not want that axle shaft falling out on the highway!
Sam
Old Sep 6, 2010 | 12:06 PM
78ford351m's Avatar
78ford351m
yeah I was going to post back saying that is what I did. Now just need some direction in getting my disc kit installed. Can't figure out how the brackets go on LOL
fridgeddiesel
Oct 18, 2013 11:14 AM
awhtx
Large Truck
Mar 25, 2010 01:35 PM
67lunargreen
Mar 2, 2009 11:08 AM
1ford1
Apr 19, 2007 06:01 AM
fionn
Jan 19, 2001 03:19 PM
