leaking anitfreeze
Old Sep 5, 2010 | 03:13 PM
driller tom's Avatar
driller tom
leaking anitfreeze
My 86 is leaking antifreeze from the the front of the engine, it looks like its coming from just above the the lower radaitor hose. Would this be the water pump or something more serious?
Old Sep 5, 2010 | 04:11 PM
johnnyneutrino's Avatar
johnnyneutrino
Most likely the water pump. Ther is usually a small hole at the bottom of the water pump. Any coolant coming out that hole indicates the internal seals have failed. Other causes are leaking hoses. Check the condition of the hoses.
