Glow Plug Harness? Leaking Oil
Hey yall. Did my coolant filter a few weeks ago and did my oil cooler this past week. Well while looking at the truck last night and this morning I see some oil residue on the head. Its comming from this harness going into the head. One per cyl. The last 2 on the passenger side are leaking oil. You can push down and oil comes out and pull it up a good 1/8in to 1/4in. Is this the glow plug harness. If so is this something I can fix easy or do I have to pull the valve cover to do it. Heres a few pics. Thanks
http://i43.photobucket.com/albums/e3...uck/truck3.jpg
http://i43.photobucket.com/albums/e3...uck/truck2.jpg
http://i43.photobucket.com/albums/e3...uck/truck1.jpg
Sorry still cant figure out how to put the picture in the post. Went to advance and tried putting the link in the button to add picture but it keeps comming up with red X's
Sorry
Sorry
Ok great its the GP harness. Now is there a way to maybe pull it and re-o-ring the connector. Or something to keep it from leaking. Does the wire go stright though or is there a plug there? Cant really tell. The battery terminal is actually really good. That is anti-seize. Its kinda messy but over the years I have found that its the best stuff to keep the corrosion away and its conductive to so. I just paint it on. It is messy though.
That is not the way I read it. I see it as getting the harness off all 4 gp's 1st and then removing the gp's. Please someone with more exp. on this chime in.
Yeah I am not sure thats why I put a ? mark. I think its just a harness that connects on to the gp's. I think the gps are screwed in and the harness is just pushed on. I think I understand that the connector that is on the harness that goes through the head is the one with the o-ring? Just need to know about this special tool to take the harness off as I dont want to break it and have to by another, and the o-rings also. Is there a part#. Or do they just come on the harness?
on
I think the glowplug harness o-rings can be had with out the harness. I dont know the part number sorry.
yes the harness hooks to the glowplugs. the glowplugs are threaded in to the heads and would have to be removed after the harness.
the special tool to remove them without breaking them sucks and will also break them. use a some wire and wrap it around the harness connector were the tool would go you will have better luck.
the eng light is on , the code say , GP #5 is faulty . I just bought it from Ford and I want to replace it tomorrow . I hope I can disconect the wire harness without problems . Thank you very much.juan
