No low range 4wd
Old Sep 4, 2010 | 01:24 AM
ChunderDownUnder's Avatar
ChunderDownUnder
No low range 4wd
4wd is working but there is no difference when I put her in low range. Where do I start??
Old Sep 4, 2010 | 05:46 AM
SSSimon's Avatar
SSSimon
Hey Brian, you haven't been tricked by the foot on the brake shift 'feature' have you?
You have to put your foot on the brake with the vehicle stopped before it will shift into low range. Call me a geek, but the only reason I know is cause when I bought my F250 I sat up all night and read the manual from cover to cover. I know it is sad, but hey, if your problem is as simple as that, well it was worth it. I actually took mine out and tried it the next day - that's really the only reason I remembered the 'foot on the brake shifting into low 4WD feature'.
Regards,
Simon
Old Sep 4, 2010 | 06:48 AM
ChunderDownUnder
Yeh had me foot on the anchors. Put it in neutral as well.
Old Sep 4, 2010 | 06:53 AM
megawatt00's Avatar
megawatt00
I would pull the plug and make sure all is well going to the motor Brian it may need to be cleaned.
Old Sep 4, 2010 | 06:57 AM
SSSimon's Avatar
SSSimon
Was the trans loaded up? One last thing to try could be to reverse a little bit to free up any torque build up in the tx case, then back into neutral and try again.
If still no luck I guess it is out with the circuit tester to check the switch is providing the signal and if the signal is reaching the tx - and the connections as per previous post from Jim.
Old Sep 4, 2010 | 09:07 PM
ChunderDownUnder
Dont worry guys, Im a dumba$$. Wasnt doing it right. All good now. Thanks all
