My earlier post was for the front end. For the rear end I would use a more viscous solution. Click on the link that was provided and read the paragraphs at the bottom. friction modifiers should not be required with the blends listed.
Add on
NOTE: AMSOIL Synthetic Gear Lubes do not require the use of the additive "Friction Modifier"
Reason: Added note
