truck shudder came back?
Carrying a heavy plow around with the weight of a diesel in front, there is no doubt they're wore. Inspect them and see if the springs are coming in contact with the frame. For a good look you would need to disassemble but at that point you may as well replace them.
propane torch will burn the bushing, but will probably not get the bolt and nut hot enough to disassemble - they get stuck real good sometimes. What's the torque-rating of that Kobalt impact, and what line and tank pressure does it need to achieve it (1/2" vs. 3/8" line, and 175 psi vs. 120 or so)?
The easiest way of doing them bushings would be with an oxy-acetylene outfit, get the bolt and nut red hot and impact them till they come out or break, then burn the bushings out and install new polyurethane bushings in their place.
on the website it says the impact is good for 500 pounds of torque, requires 4cfm at 90 psi, it will be running off an 12 gallon 1hp in my garage or if I go to my uncles it will be on a 30 gallon 3hp compressor, and sadly I no longer have access to acetylene outfit
also I only have 20' of 3/8" line
How many miles on your truck.
I would almost bet the spring shackle at the front of the front springs has the upper bushing out.
I drove myself nuts trying to find a thump I felt when I hit a pot hole.
I replaced the front springs and added a couple leaves.
When I pulled the front shackle down out of the frame, no bushing, bolt worn almost in half and big wear spots on the side plates of the shackle.
A pair of new shackles, and new bolts, no more thump.
quaddriver
20
11-01-2011 02:24 PM
