power windows
Old Sep 3, 2010 | 12:38 PM
1989Ford7.3L's Avatar
1989Ford7.3L
power windows
i have a 1991 f250 with electricv windows. My passenger side window stpped working so i took it apart. I was abble to see that the probles is a stripped gear that raises the window arm. It looks immpossible to change the motor or gears. Has anybody done this or know how to? Thanks
Old Sep 3, 2010 | 01:07 PM
bobbyjo9's Avatar
bobbyjo9
Drill out the pop rivets, slide the regulator off the track and remove the whole unit. Remember to support the window though cause the motor is what stops it from falling out of the track
Old Sep 3, 2010 | 01:11 PM
jas88's Avatar
jas88
You don't even have to remove the regulator. There are 3 bolts that hold the motor to the regulator, only one is exposed. If you drill out the door frame where the dimples are with a 1/2" drill bit, you can get to the other 2 bolts. Then just pull the motor out of the back of the regulator.
Old Sep 3, 2010 | 07:01 PM
1989Ford7.3L
thanks guys ill get to that when im home on break
Old Sep 12, 2010 | 07:28 PM
Quick69's Avatar
Quick69
did this to mine today, drilled the 2 holes and unbolted it. I took the motor apart and just had to replace the 3 plastic cylinders behind the gear. It works like a charm now.
