Trouble shooting the DPFE
Old Sep 3, 2010 | 09:11 AM
MikeB 88's Avatar
MikeB 88
Printed the Ford DPFE Sensor Test instructions from the tech link at the beginning of the Ranger section. The only way I can get a probe into the back of the electric connection is to use paper clips. Here is my problem besides the fact that I'm not an electrical genius.
Turned to key to the run position (on), connected the negative probe to the negative battery post. probed the top wire (DPFE signal) the DPFE connector and got 0.00 volts. Same with the middle wire (signal return). Am I doing something wrong?
However, if I touch the paper clip/probe I get a .54 volt reading. My Ranger has the 2.5L and the DPFE housing is black plastic.
Old Sep 4, 2010 | 07:13 AM
pawpaw's Avatar
pawpaw
Disconnect the DPFE electrical connector.
At KOEO, from the connectors VREF contact, you should have 4.0-6.0 vdc to a good clean, unpainted ground point, or to the battery B- post.
Old Sep 5, 2010 | 03:31 PM
MikeB 88's Avatar
MikeB 88
Thanks, I was having trouble getting a pin in the connector to get a good reading. Wound up reading through the many threads here about it and decided to replace the sensor. Took it for a 6 mile drive down the highway and so far the light has stayed off. Time will tell.
Old Sep 5, 2010 | 05:19 PM
pawpaw's Avatar
pawpaw
Yup, it's difficult to do back probing & to be certain of the results.
The DPFE sensor has earned it's place high up on a misbehaving EGR system suspect list, so maybe you've guessed right, lets hope so.
old broke prospector
Apr 9, 2013 07:43 AM
pezzonovante
Escape & Escape Hybrid
Nov 17, 2009 08:06 AM
moorefc
Dec 31, 2008 05:49 PM
Aufin
Nov 4, 2006 09:47 AM
eigenvector
33
Aug 7, 2006 01:07 PM
