HPX ???
Old Sep 2, 2010 | 07:21 PM
F-250 Super Duty's Avatar
F-250 Super Duty
HPX ???
I've been looking at some of the HPX rails and want some input. Hard line or soft line. Every bone in my body is saying hard line but just wanted to make sure I'm going with the right choice?
Old Sep 2, 2010 | 07:42 PM
TinyWonder's Avatar
TinyWonder
I'm watching this thread with care. I'm thinking the exact same thing.
Old Sep 2, 2010 | 08:03 PM
binuya's Avatar
binuya
I went with the flexible line. It's double insulated for heat protection and installs easily due to its flexibility. Just make sure when tightening down, the line doesn't twist into anything and make contact, i.e. turbo. I have never heard of a flexible HPX failing on anyone.
Old Sep 2, 2010 | 08:07 PM
Izzy351's Avatar
Izzy351
Went with the steel HPX. Fat chance of it failing......
Old Sep 2, 2010 | 08:19 PM
Mark250's Avatar
Mark250
Steel line here. Can't say I noticed much difference but I fell better with it on anyway.
Old Sep 2, 2010 | 08:43 PM
USAF CCM's Avatar
USAF CCM
I had a soft line.....fine print said it would only last one year.....it failed at about the one year mark.
I just ordered the stainless steel line from Dennis at Sinister Diesel; formally known as ITP Diesel. BTW, I also ordered RiffRaff's FRx fuel crossover lines.
Both items are on Back Order.
Old Sep 2, 2010 | 08:47 PM
Izzy351's Avatar
Izzy351
I did. Engine used to jump around a little in the engine bay, but after that mod, it sat in there barely wiggling...
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Had a soft line for 3 1/2 years from DI Performance and not a drip...
Old Sep 2, 2010 | 09:15 PM
binuya's Avatar
binuya
In my case it mellowed the idle noticeably, or to put it another way, it sounded more even. The biggest change for me is that it nearly eliminated the romps. I run Delo 400 and on cold start ups it would romp fairly regularly below 45F and occasionally above 50F. After HPX, I recall only a couple occasions it romped at freezing temps, and both times I remember not leaving the glow plugs on as long as I should have.
Old Sep 2, 2010 | 09:16 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
SS Line here, Got mine from Sinister Diesel.
