Lacquer Primer Question
Old Oct 11, 2010 | 11:28 PM
fettless's Avatar
fettless
FYI: Laquer remains soluable, and it expands and contracts at different rates than urethane.
Urethane cures with a hardner, it becomes non-soluable once cured.
Urethane over laquer...no! Though the urethane is hardend the substrate (laquer) is not. The substrate (laquer) will always remain soluable beneath a urethane top-coat. Sanding scratches, filler work, laquer checking (crows feet) WILL make their way all the way to the topcoat. It WILL move beneath the topcoat and eventually move the topcoat.
The only way to properly paint urethane over laquer is not to! If your going to spend the money on a good urethane paint job the laquer substrate(s) should be stripped before ever starting.
On the other hand you CAN spray laquer over properly cured urethane topcoats and primers.
Jeff
Mota
Paint & Bodywork
Feb 16, 2015 10:13 AM
bassdude
Paint & Bodywork
Apr 4, 2014 11:09 PM
Icicle
Paint & Bodywork
18
Oct 9, 2010 01:11 PM
jniolon
Paint & Bodywork
20
Sep 26, 2008 06:46 AM
JLb300
Paint & Bodywork
Jun 1, 2004 10:56 AM
