oil pan blues
Old Sep 2, 2010 | 03:10 PM
the Canadian's Avatar
the Canadian
oil pan blues
Can anyone tell me changing oil pan is a driveway job or to big thanks.
Old Sep 2, 2010 | 04:03 PM
HILLBILLY BOB's Avatar
HILLBILLY BOB
I would not do it in the driveway
Old Sep 2, 2010 | 08:48 PM
BradyCouchman's Avatar
BradyCouchman
i reaplaced my engine in my drive way. if it is 2wd you almost have to pull the engine out to change it, so if you can pull the engine then sure you can do it in the drive way.
Old Sep 2, 2010 | 09:51 PM
BobbyFord's Avatar
BobbyFord
When you pull the pan it would be a good time to replace the rear main seal.
Old Sep 7, 2010 | 01:47 PM
312's Avatar
312
if it aint broke dont fix it.
Old Sep 7, 2010 | 10:47 PM
BobbyFord's Avatar
BobbyFord
I'll bet the rear main is leaking now. If it ain't, it will be.
Old Sep 8, 2010 | 09:01 AM
Unimog005's Avatar
Unimog005
Another thing to consider is blow-by at your rings....I had a "leaky oil pan seal" that, when replaced, caused the top end of the engine to blow out oil....as the piston rings were gone....so if you're changing the pan to "fix a leak" you might want to investigate further first...
