Which engine is best?
Old Sep 17, 2010 | 09:29 PM
  #91
FlyByNight's Avatar
FlyByNight
Originally Posted by tex25025
Also add in the fact that the 6.0 has almost zero space under the hood compared to all the space that the 5.4 has in the 150, which is even smaller then the SD. That one really has me baffled. I could almost fit in there and work on the engine and I'm 6'3".
****! This means you have the reach on me too!!
Old Sep 18, 2010 | 04:45 AM
  #92
HAPPY_trails's Avatar
HAPPY_trails
Originally Posted by Troy Buenger
If I were in the market for a half ton gas truck it would be without a doubt the 6.2. This engine is showing pretty impressive results in the Super Duty and will be a monster in the F150. The 5.0 and Eco engines look very impressive also. These are all great choices and the decision can be tough.
Bottom line is I truly believe all the '11 engine lineup will be MUCH better than the Tritan line of engines...
Let's list some of the historical Triton woes for all the selective memories:
2V Series 4.6 & 5.4
Poor power
Poor fuel economy
Pistin Slap
Spark Plugs shootin out of heads
3V Series 5.4
Uninspiring power
Spark plugs still shootin out of heads
Cam phasers
Spark plug failures
Carbon build up on spark plugs
Enjoy the new '11 engine lineup, I think they'll all be great. Too bad the diesel got dropped.
I have nothing but absolute praise for my 2V 5.4L. I have 240k on the original engine (and transmission 4R100) with no major failures. The only recurring issue I have is the #4 coil pack shorting out and needing replacement (which only made it misfire, and usually only under load). The other coil packs are original. Spark plugs have been changed twice. Back in 1997 when they came out, Ford's Triton engines were top dogs and were praised for their power. Fuel economy is the same for pretty much any other pickup that was available ten years ago. Piston slap is really only an annoyance rather than an actual issue. Mine has exhibited piston slap during cold starts since before it hit 100k and still does it today. It's been a good truck and will continue to be used until it finally dies.
Old Sep 18, 2010 | 05:36 AM
  #93
tseekins's Avatar
tseekins
Veteran: Coast Guard
Excellent post sir. The folks at my dealer told me just the other day that they've had to work on only six 5.4L engines since they came out in '97 IRT cam phasers and oiling issues. They said that they've never broken broken a plug during extraction.
I'll assume that they are being honest as this dealer's service department is all he has going for him. His inventory sucks and he's a fairly high volume dealer, just really old fashioned.
Old Sep 18, 2010 | 01:30 PM
  #94
FishOnOne's Avatar
FishOnOne
No doubt the 2V engines are reliable if you can escape the spark plug blowing out of heads issue.
I had a 98 F150 SC 4X4 and it's power was shy of desirable (even in '98 standards) especially when pulling my boat and it couldn't pass a gas station and this is comparing to a similiar equiped Z71 350 throttle body injection system.
I think the 6.2 is the engine Ford should of had years ago instead of the small bore Triton engine's that needed supercharging to get enough air thru the small valves. Actually this engine design was started years ago and was killed and revived several times.
Old Sep 18, 2010 | 03:52 PM
  #95
HAPPY_trails
The first time I ever even heard of the spark plugs blowing out of heads was when the 3V 5.4L's came out. I've never heard of this issue with the 2V. But even if there was, this is an issue with what, less than one percent of all 4.6Ls and 5.4Ls made since 1997? The 4.6L has been made since the early 90's, and I've never heard of any spark plug issues with this engine (had one in a Thunderbird and it was equally as reliable as my truck).
Old Sep 18, 2010 | 06:45 PM
  #96
FishOnOne's Avatar
FishOnOne
Nope... Spark plugs blowing out of 2V engines also. Just Google Ford spark plug problems and see for yourself. Also spark plugs popping out is popular in police vehicles 4.6 and V10 engines that pull heavy loads
YouTube - Ford Triton Engine BLOWN SPARK PLUGS.
Old Sep 19, 2010 | 02:30 PM
  #97
johndeerefarmer's Avatar
johndeerefarmer
[QUOTE=YoGeorge;9340399
It sure seems to take Ford a while to really get something right, again reinforcing the idea that I do not want to be a "beta tester" for any kind of EcoBoost engine. Even if prototype test engines give stellar test results, moving certain parts (like turbos) to mass production could create yet more problems arising from mass production status.
George[/QUOTE]
The turbos are Honeywell Garrett GT15 water cooled turbos. Garrett makes turbos for on the road as well as racing. Don't worry about the turbos they are tried and tested.
TurboByGarrett.com - Turbochargers
Old Sep 19, 2010 | 04:02 PM
  #98
Greg B's Avatar
Greg B
Weren't the variable geometry turbos on the 6.0L engines Garrett? They were very problematic if the truck sat a lot.
Old Sep 19, 2010 | 04:27 PM
  #99
HAPPY_trails
Nope... Spark plugs blowing out of 2V engines also. Just Google Ford spark plug problems and see for yourself. Also spark plugs popping out is popular in police vehicles 4.6 and V10 engines that pull heavy loads.
Very interesting, it must be more common than I thought. Still couldn't find a figure as to how many engines have been affected. I still think the Triton engine line has been a good one. For every one unhappy owner, there's probably hundreds of happy owners. I wouldn't think twice about buying another one if I needed to. Mine has performed flawlessly for a very long time.
Old Sep 19, 2010 | 04:45 PM
  #100
tex25025's Avatar
tex25025
Any vehicle that sits a lot runs the chance of having problems. VGT turbos didn't also like having an EGR system attached to it when people weren't working the truck to help clear out the carbon buildup. I wouldn't blame that on the turbo.
Old Sep 19, 2010 | 07:26 PM
  #101
FishOnOne's Avatar
FishOnOne
I agree with Tex and to add Diesels that burned Low Sulphur Diesel really plagued these variable vane turbos with soot.
The gas engine turbo's will be free of all the soot that their diesel counterparts and to deal with.
Old Sep 19, 2010 | 07:46 PM
  #102
johndeerefarmer
My 2005 sits most of the time, most trips are 5-10 miles. In 5 1/2 years no EGR or turbo problems. Now I do tow with it every once in awhile with 5000 to 10000 lbs. So either the towing blows the carbon out or I have been lucky.
I remember about 35 years ago my grandma had a 69 Pontiac Tempest with the 327. About once a month we would get in it and go "blow out the carbon". That car would just fly! And the scary part was grandma had to look thru the steering wheel not over it.
Old Sep 19, 2010 | 07:57 PM
  #103
tex25025's Avatar
tex25025
It depends on how you drive those 5-10 miles as well. Do you drive like Ma and Pa Kettle or do you drive like Dale Jr.?
Towing that amount of weight does help it out quite a bit. I would honestly say that it's a little bit of both luck and the towing unless you really rag on that truck on those 5-10 miles too(which if you do, I would be worried about other things not just carbon buildup).
Old Sep 19, 2010 | 08:09 PM
  #104
YoGeorge's Avatar
YoGeorge
Good to hear, jdfarmer...this definitely makes me feel better about the turbos themselves, but there are certainly a lot of other pieces too. I'm actually anxious to drive an EcoBoost.
By the way, the small Pontiac V8 was a 326, not a 327, and was enlarged to 350 in 1968 for the Tempest/LeMans and Firebird. So grandma's car was either pre-'68 with a 326 or had to have a 350 in it. But blowing carbon out of a car sure could be fun.
George
Old Sep 19, 2010 | 10:08 PM
  #105
GuyGene's Avatar
GuyGene
Aw, just go ahead and get a Chevy!
Check this out:
Ford Introduces Three New Light-Duty Engines for 2011 F-150 Pickup Trucks - PickupTrucks.com News
Me, I would get the 5.0 in F150.
