Moves when in park
Old Sep 2, 2010 | 09:40 AM
1979BOB's Avatar
1979BOB
Moves when in park
I have a 2000 EXP that will not stay in park. If parked on any incline it will move. Any thoughts?
Thanks
Old Sep 2, 2010 | 10:38 AM
dirtmonkey11's Avatar
dirtmonkey11
There are 2 things I can think of that would cause this, one would be the shift linkage is not engaging all the way on the transmission and not putting the vehicle in park. The other thing I could think of is the park pin in the trans is either broken or not engaging.
Old Sep 2, 2010 | 12:38 PM
minitrk's Avatar
minitrk
Im going for the shift linkage under the dash. If you look at the column under the dash you should see a bracket that has come loose. There are lots of posts here about it, I even had this issue.
Old Sep 2, 2010 | 06:06 PM
alloro's Avatar
alloro
Read this thread to help look for the two torx bolt you're supposed to tighten. Post #10 has pictures of it.
https://www.ford-trucks.com/forums/8...t7137650.html?
Old Sep 2, 2010 | 09:24 PM
1979BOB's Avatar
1979BOB
Thanks guys I will check it out. To bad I didn't check before it rolled into a pole and caused $3,000 in damage.
Old Sep 3, 2010 | 12:49 AM
alloro's Avatar
alloro
That's one expensive pole.
2FordTrucks
Jun 19, 2022 08:29 PM
WilliamKG88
May 28, 2015 12:49 PM
mike L
Apr 2, 2015 09:25 AM
michaelskerrett
Jun 25, 2014 11:18 AM
fnx4wheeler
Aug 31, 2007 05:37 PM
