all my lights flicker...
Old Sep 1, 2010 | 08:38 PM
f100help's Avatar
f100help
alternator is newish, but all the lights (interior/exterior) flicker...im thinking i already have a bad ground because of the starting system not always want to start the truck, its like i have to wait for it to cool down or something?
i need to buy a voltmeter i guess to check the alternator but where else should i check?
Old Sep 1, 2010 | 09:35 PM
Dskeet6's Avatar
Dskeet6
check the voltage regulator on the passenger side inner fender..... see if those bolts are loose.... it grounds on the inner fender.... also see ground wire from battery to engine block.
Tees77f150's Avatar
Tees77f150
I would say if you have flicker, or paulsation, it is a due to a bad ground. Make sure your battery has a good ground on the block. There should be another from the block to the frame. Also check your voltage regulator, and make sure it has a clean ground too. Depending on what year you have it will be on the radiator support, or the passenger side fender well near the battery.
As far as not starting and your sure it is heat releated, I could guess it is your ignition control modual. ICMs are notorious for this, and is a good idea to carry a spare with you at all times.
Old Sep 1, 2010 | 10:00 PM
SparkyRnD's Avatar
SparkyRnD
I'd say ground too. Also, make sure you don't have any pinched wires or bare wires rubbing metal
Old Sep 2, 2010 | 06:25 AM
jim collins's Avatar
jim collins
All of my lights were doing that ,plus going off and then back on last week , which was not good at freeway speeds. I replaced the headlight switch and the problem went away.
Old Sep 2, 2010 | 11:48 PM
f100help's Avatar
f100help
ive been looking at hundreds of threads over the past few hours, seems thats the common issue, thank you
1968 F100 Ranger
21
Jan 25, 2015 03:53 PM
036.0stroke
Sep 25, 2013 10:07 PM
Ubbzy
Jul 11, 2009 11:11 PM
TallDaveWW
Aug 29, 2007 05:12 PM
