Hesitation and Flickering Radio Light at Idle
1999 Ford Explorer XLT V6 SOHC, 95000 miles or so
Past few weeks or so i have noticed my car seems to hesitate when accelerating from idle.
Also in the past couple days when the headlights turn on which causes the radio lights to brighten the radio lights flicker when at idle. if i accelerate at all it stops flickering. The flickering isnt constant. it will flicker for a second or two then stop, then maybe 5-20 seconds later it will flicker again.
one idea i was thinking for the lights problem is maybe the alternator was starting to wear out and couldnt quite produce enough juice with the headlights, a/c, radio, etc. running. just a thought. if i get some time tomorrow at work i will run it to somewhere to get them to check it.
any ideas? are the problems possibly related?
Thanks!
Thanks!
The voltage regulator is inside the alternator. I'm think you have a bad ground then. If a ground has become corroded or loose, then you would definitely get a flickering going on. I would run a new ground to a known good source. If that still doesn't fix it, I would suspect something may be wrong with the radio itself.
Plankton
17
10-10-2016 05:09 PM
mkm43057
09-04-2016 02:51 PM
