shifter pattern
Old Feb 17, 2003 | 11:00 PM
xl500's Avatar
xl500
Question shifter pattern
The pattern on my 1970 F-250 4 speed has reverse going to the right and down. Anyone ever see reverse to the right and up? I have not, but was told such a thing existed. Not earth shattering stuff, just thinking during this lovely Connecticut blizzard.
Old Feb 17, 2003 | 11:26 PM
FrayedSanity's Avatar
FrayedSanity
shifter pattern
Sounds like you have a NP435 (New Process) trans. The up/right pattern is what I have in my truck, a Borg-Warner T-18.
Other trans might have this pattern, but these were the 2 most common manuals that I know of.
Old Feb 18, 2003 | 08:59 AM
Fordzlla's Avatar
Fordzlla
shifter pattern
My '70 F-250 4x4 has a t-18 that was swapped in for the original 3 speed. reverse is up.....
my parts truck (70 f-250 4x4 also)has an NP435 factory installed. Reverse is down.
Old Feb 18, 2003 | 02:39 PM
idealtrucks's Avatar
idealtrucks
shifter pattern
i just bought a 4speed to replace my 3speed. it is out of the truck and i just went and checked it and it has reverse right and down. It says borg-warner on the side of it, what model would it be?
Old Feb 18, 2003 | 05:59 PM
xl500's Avatar
xl500
shifter pattern
On my door tag it says trans "A", it is a 1970 F-250 Heavy Duty Special.
Old Feb 18, 2003 | 09:47 PM
FrayedSanity
shifter pattern
Couldn't tell you for sure what you have. I know T-18's, and I know NP435's, only because I've owned both. The T-18 is behind the 390 in my current truck, and the NP435 was behind a 300-6 in a `68 I owned breifly. It's now a trailer as the front end was shot beyond repair. Rust and 2 different collisions made it very undesireable
Best I can tell you is to look on the case for any identifying #'s and see if anyone here can tell you what it is. You can also check here to see if you can identify it.
Hope this helps!
xl500:
Can't really help you, either. Door tags are a bit beyond me. I've had mine decoded, but I can't remember what exactly it said (without going and looking at it) and I have no clue where I put the info I got back! Maybe someone else can chime in?
Old Feb 19, 2003 | 08:42 PM
OldBlue67's Avatar
OldBlue67
shifter pattern
"A" is the New Process, NP- 435 (according to my info) I'm not sure about idealtrucks, but it sounds like a T-18.
