Were can a person get the first section coming out of the transfer case that goes to the first universal joint, the universal joint was squeaking but came to find out that it had alot of play in it, It was very loose and slid back and forth so its been wollowed out ,, need a new and then it would be tighter going in.. Were is a good place i can get one???
What year truck and/or T-case model?
1356 has splines, 4407 has bolt-on flange, changed models in mid '95 I think.
You'll need to know this when searching for it.
Well i can take it back out but all i know it was smooth on the end i just slid it back into the boot in the trasfer case... on outer edge on the end it was smooth.. just slid it back in there an picked it up and bolted it back on to the back axle.. Its a two piece deal.. Is that what you have??? yes its a slip yoke, all new to this sorry
I've got a two piece drive shaft but they are different depending on your truck. Some trucks have a single piece rear DS. Both of my trucks are extended cab so I have a two piece. The one I can get rid of has a slip yoke with a smooth outside and splined inside that just slides right into the t case. If you need I can post a picture.
I think thats the one i need,,, what would you need from me to make sure its the same one??? im leaving for church camp tomorrow and wont be back till money,, i would be interested in it if its the same one.. I wont be able to take a pic or drop mine again till monday to get a measurement for you... Would that be ok???
Whenever you can get to it is fine bud. From what I understand if you have a BW 1356 t case then it should fit. Is your truck extended cab or what? If you want to measure it then that's even better. Let me know your email. I check mine more than here because I get it on my phone.
Hey im sorry,, funny after we dropped it and put it back it hadnt squeaked.. but i know it shouldnt be that wore out.. Mine is a reg cab truck, 1994.5 powerstroke 5 spead. How do i go about finding out what trans number i have? Email is fine mine is bohawg@verizon.net , problem is i dont check mine that much.. haha but i will. Please give me a week or so.. I have my tractor in my garage now trying to repair couple stripped bolts were the tractor was split before i go it.. leaking to much so i figured i would jump on that this weekend.. Just seems like right not not enough time in the day, Plus hunting season is coming quick.. Had church camp last weekend.. haha the numbers that your saying if i have that or not were or how can i find out if thats the same as mine
putting it back on top of post so hope he will see this, trying to get back with someone,, how do you get ahold of anyone on this site? other then replying back on forum??
scatgo thats what im trying to get ahold of him for, cause im needing it.. if you had read the post why would you jump in and try to get him to sell it or give it to you?????
The email i gave you switched from verizon to another email so i dont have it set up yet. if you can send me somethning to bohawgme1@yahoo.com . that way ill have your email... thanks
