IAC help
Old Aug 31, 2010 | 09:03 PM
pintoches's Avatar
pintoches
IAC help
Trying to help Older man out! He has a 96 E150 5.8
he was in the store and got a code P1507 Idle air control IAC under speed error.
he changed the IAC and still has the same code,
please help
Old Sep 1, 2010 | 02:48 AM
TexasGuy001's Avatar
TexasGuy001
Try clearing the codes and see if it comes back. He can also drive it some and see if it goes away. Is the check engine light still on? On OBDII vehicles it can take several run cycles for the computer to readjust.
Old Sep 1, 2010 | 07:28 AM
pintoches's Avatar
pintoches
After he changed the IAC and cleared codes it ran great for about 20 mins, then got same code after it would not idle again!
Old Sep 1, 2010 | 07:38 AM
DBGrif91's Avatar
DBGrif91
Sounds to me like perhaps there's a faulty connection between the computer and IAC. Try to trace the circuit between the computer and IAC, also check for dirty/bad grounds.
