ac bulbs out
Old Aug 31, 2010 | 08:22 PM
hiredgun18's Avatar
hiredgun18
ac bulbs out
One of the bulbs that are behind my ac ***** went out,how would one get back there to change it out???
Old Aug 31, 2010 | 08:42 PM
riverrat41's Avatar
riverrat41
Bump.....I have had mine not come on when I turned the lights on,pecked on it a little and it would come on.Has happened several times but it was in the winter.
Old Aug 31, 2010 | 11:53 PM
hiredgun18's Avatar
hiredgun18
The is FTE,someone has to know!
Old Sep 1, 2010 | 12:18 AM
BigAlsPSD's Avatar
BigAlsPSD
I'm not sure on the exact issue and how exactly to go about replacing the small incandescent lights, however the entire control panel can be removed, and from there could be assessed to find a solution? If you do it, make a write up and we can all learn from there. In my searching I have only heard of entire control panel replacements. But my thoughts are always "somebody put it together, so this somebody can take it apart!"
Old Sep 1, 2010 | 06:10 AM
GigAg04's Avatar
GigAg04
I have one out too...its on the left side.
In for the solution...
Old Sep 1, 2010 | 07:24 PM
hiredgun18's Avatar
hiredgun18
BUMP... I would do it,but im not gonna swing into it without any know-how. I was hopin someone had done it before and had a write up.
Old Sep 1, 2010 | 07:40 PM
big poppa's Avatar
big poppa
Hopefully its just a regular ole peanut size bulb you can get in any parts aisle. If its anything like the bulb behing the 4x4 switch its goofy looking and looks like some money, still haven't replaced it. Somebody will be by soon..
Old Sep 1, 2010 | 07:53 PM
mikeyc0120's Avatar
mikeyc0120
Im not sure what kind of bulb is in the ac panel, but I know the bulb that backlights my headlight switch was out for a while. I had to take apart the unit and replaced it with an LED. Its real tiny, smaller than the bulbs that are in the door panel courtesy lights.
