Found my steering problem!
Old Aug 31, 2010 | 04:30 PM
merccougar93's Avatar
merccougar93
The fracture is right where the steering box attaches to the frame just on the bottom, not running up the side, so its not that hard of a fix.
We found it while we were adjusting the steering box, and i was checking the play in the steering, my dad saw the steering box move left and right-several inches- instead of the tires. So after a few seconds of looking underneath, thats what i found.
ok, those pictures didnt blow up like ones before did. ill see if i can get better ones up
Old Aug 31, 2010 | 05:00 PM
HIO Silver's Avatar
HIO Silver
Ewwww.....pressure wash! Seriously, a clean (cleaner?) undercarriage really helps in doing visual inspections.
Glad ya'll found it before something really bad happened.
Old Aug 31, 2010 | 05:24 PM
merccougar93
yeah, that will be taken care of tommorrow, maybe the day after, but its not bad, ive got a 1/8" clip I can cut so span over it 4 inches on both sides with bolt holes i can puddle weld to the frame,shouldnt be a long fix
Old Aug 31, 2010 | 05:56 PM
HIO Silver's Avatar
HIO Silver
Cool. 'hope it doesn't catch fire while laying down the bead!
Btw, you do know to "stop-drill" the crack, right? That's probably not the right term but that's the one we used in the Navy.
Old Aug 31, 2010 | 06:20 PM
merccougar93
i know what your talking about. Drill a small hole at the end of the crack to stop is from spreading-yes i do
Old Aug 31, 2010 | 10:15 PM
HIO Silver's Avatar
HIO Silver
Yep. That's what I meant. Didn't mean it as a ping as if you're a newb. 'just trying to help.
Any idea what caused the crack? That's not what I would consider normal.
Old Aug 31, 2010 | 10:33 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Very normal for our Ford trucks, there is even a TSB for it outlining the Ford technicians procedure to "fix" it...
Hmmm... can't find the official TSB for it at the moment...
Josh
Old Aug 31, 2010 | 10:43 PM
HIO Silver's Avatar
HIO Silver
Hmmm... I guess engineering across the Big 3 is pretty much the same cuz I've read bowties have had the problem and even the newer Rams crack their frames. In fact for the Rams, there's a company that manufactures a brace that bolts to the steering box and transfers some of the load to the right frame rail.
Thanks for the heads up. I'll keep an eye on my rig.
Old Sep 1, 2010 | 06:03 PM
merccougar93
no offense taken. I knew your makin sure i was doin it right. i think it was poor "prior ownership". Ill see if i can find that TSB. Thanks for the heads up on that Bullit
Old Sep 1, 2010 | 06:18 PM
Bullitt390's Avatar
Bullitt390
I tried looking, couldn't find it and gave up. I know Number Dummy has mentioned it a couple times in threads.
Going off memory, I believe the crack was welded and then a "plate" was bolted to the frame rail. Although I would weld the plate and not bolt it.
But to refresh, it was a very common problem for 2WD and 4WD trucks to crack the frame.
As a matter of fact, and I hate to admit it, but the frame on my truck has a small crack. Never knew about it until recently when I swapped in the manual tranny and noticed it when installing the z-bar brackets.
Josh
Old Sep 1, 2010 | 06:41 PM
merccougar93
ive got a welder here, and some metal building plates and i-beam bolts that will go in place- ill post some pics when its done. Ill see if i can find it
Old Sep 1, 2010 | 07:22 PM
berry1234's Avatar
berry1234
That sludge reminds me of what we pulled out of the deep fryer at Weinerschnitzel.
Old Sep 1, 2010 | 07:47 PM
bmarkline's Avatar
bmarkline
Holy moly! Is this all of the dents or just a specific wieght of truck? ie: F-150's, F-250's ect? I know they have different steering setups for the 8 lug trucks
Old Sep 1, 2010 | 08:10 PM
merccougar93
well, you can check yours for signs of stress to see if you have a problem, its not a hard find. Im not sure on the years though, although im sure bullitt can tell you
Old Sep 1, 2010 | 08:11 PM
merccougar93
Its not as bad as the floor gets at the local Tastee Freez. Flour and milk thats been walked on all day gets pretty nasty.
