Annual Reminder - Grease Your Front Unit Bearings!
Maybe someone who is changing out their hub assembly will give you their old abs cable? Not that I remember for sure but is one side longer than the other?
You can fix your abs light on the dash by stragetically placing a piece of black electrical tape over the light. Totally kidding of course.
TinyWonder
TinyWonder
grease fitting
i did mine in january when i did my ball joints, guess i should get on the August schedule though so i get the convenient Pop reminder!
i have a fitting to screw on my grease gun that has 45 degree taper or so that worked like a gem for this, think it was 3 bucks at my farm supply store here locally, worth every penny.
And going to toss out with this one, for those with ESOF 4x4, do the guzzle hub maint while you are there, I like my new warn hubs, but could have saved some serious coin had I just not kept putting that one off.......
I have 3 of them in my parts drawer now. He made three slightly differently to find out which one worked best. If three of you would be interested in being test dummies with these, PM me. I'll need to know how well they work. They're numbered 1, 2 & 3. They don't have zerks installed.
#29
Does that include the zerks?
Since you're relatively new around here, I'll just tell you that the first batch was just GIVEN away to those that asked. There wasn't any profit motive involved.
Is he using my dimensioned drawing to make that profit?
Just sayin'.....
Pop
#30
Good Grease??
While in Pep Boys (not a regular stop but had to go for RTV for differential) I came across some grease that I think is a good match for this service. they carry Castrol Pyroplex Blue. It is NLGI #2 and I don't see anything on the tube or the data sheet that says it has Moly in it. What do you guys think? Is it what I should I be using for the front wheel bearings? How about the needle bearings? Here is the datasheet for the grease.
JP
JP
