6.0 pushing water under boost ??? Help
Yes, definately. I was formerly an engine mechanic at a detroit diesel dealership. I had a few 60 series engines that had warped blocks and one that must have been a Monday morning machine job. Any engine that I pull the heads on gets checked with a straight edge and then emery clothed. It either one shows uneveness I will have the block machined. This thing only has 20,000 miles since it was rebuilt so hopefully there isn't anything wrong with the block.
Yes, it is the double chamber blue liquid stuff. How come that stuff sux? I read a lot about people blocking and deleting the EGR cooler. I figured it would be the same. What is the issue with blocking it off? My dad bought this pick up and now I am learning a lot about the 6.0 Thanks for your input.
Hello, I am new here but not new to my 6.0. I have been chasing a problem for about a year and can't find it. If there is anyone that has ran into this problem before please let me know what you did to repair the problem. OK to start with my truck has had 6 EGR coolers and 7 oil coolers installed and that's just on this engine. The whole motor was warrantied at 38k. But back to the current problem. The cooling system is getting pressurized pushing water out of the cap. I have no oil/water, water/oil, water/diesel, diesel/water, etc. all the fluids are where they are supposed to be accept the water keeps getting pushed out. I pressurized the cooling system with a tester over night and it didn't even loose 1 pound. I checked the tank with the dye tester, no color change. I've changed 4 caps of all different brands, all the same. Upon cold start, I get no smoke at all and I've got 4" magnaflow with no-cat. If there was any coolant in the cylinders, I should see some white smoke or at least condensation. I just installed a new fan clutch, nothing changed. It is not getting hot, just pressure. I live in the foothills and the pressure seems to get drastically worse while I'm climbing a hill under boost, or towing a trailer. If this was a head gasket shouldn't it leak both ways? I am thinking a crack in the intake tract, either in the intake or the heads, but that too should leak both ways. Has anyone heard of the water pump slipping on the shaft? If that was the problem, shouldn't it be getting hot?
If anyone has any ideas, PLEASE HELP.
The truck has the following mods......
AIRAID intake
Magnaflow exhaust turbo back, no cat.
Banks charge air cooler system.
Edge Juice w/ attitude
RCD EGR Cooler delete kit
AIRAID intake
scsmith42
6.4L Power Stroke Diesel
13
04-07-2023 02:10 PM
