Sponsored by: Real Truck
fuel issue 6.0 psd
Old Aug 31, 2010 | 10:46 AM
a4x4nutt's Avatar
a4x4nutt
fuel issue 6.0 psd
ok here we go 2009 e450 cutaway with a 6.0 psd, was running doggy 26,000 miles ,started to skip and stall, felt like starving for fuel.
Replaced both fuel filters now it wont even do anything but turn over and over..
primed and double checked has fuel in both filter any suggestions?
Old Aug 31, 2010 | 10:50 AM
redford's Avatar
redford
FTE Leadership Emeritus
FICM would be my first guess.
Old Aug 31, 2010 | 12:15 PM
bpounds's Avatar
bpounds
Did it ever start after changing the filters?
Did you prime it BEFORE you tried to start it?
Did you use Motorcraft or Racor brand fuel filters?
Did you use a torque wrench on the fuel filter caps?
Please provide the answers.
Old Aug 31, 2010 | 03:05 PM
a4x4nutt's Avatar
a4x4nutt
fuel issue
no it never started after filter change,
yes it was primed 3seconds on then 15 off done twice
motorcraft filters
torqued caps.
but also found out when it died the first time was turning a corner but did restart.
no water in fuel
removed top filter cover and cycled key , plenty of fuel coming out
Old Aug 31, 2010 | 03:16 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
When I ran mine out of diesel, I did key on for 20-ish seconds (until the pump noise dies), key off 10, did that 3-4 times, and it still sputtered and choked and growled for a solid 2 minutes until it was completely purged of air.
Old Aug 31, 2010 | 03:25 PM
a4x4nutt's Avatar
a4x4nutt
i tried that too,cycled until pump stops repeatdly still not even a puff or a spudder.
Shows good oil pressure while cranking,
Old Aug 31, 2010 | 03:40 PM
bpounds's Avatar
bpounds
I hope you meant 30 seconds, not 3. But even if you did, twice is a bare minumum. In fact, one Ford video floating arounds says to do it 6 times. I have just done it 3 times, and not had a problem. But instead of going with 30 seconds, I actually listen for the pump to stop before I turn it off.
The point is, that if you get a bubble into the fuel rail, it takes a long time to get it out.
But I have to say, if it never kicked over at all after the filter change, I think it is something else. Someone smarter than me will have to have a go at it.
Old Sep 1, 2010 | 03:34 AM
a4x4nutt's Avatar
a4x4nutt
fuel issue
any other suggestions? still get anything out of it
tulsacars
Mar 16, 2014 09:00 PM
gamaliel
Nov 9, 2012 12:00 PM
true blue
Oct 25, 2011 02:49 PM
jas67
Oct 1, 2009 04:03 PM
