18" FX4 'wrench' wheels
Old Sep 5, 2010 | 01:51 PM
JeepPuller's Avatar
JeepPuller
I think if I stay with the "C" rated LT tires I will be better off with loads than the "P" tires and better riding than with "E" rated LT tires. It all comes down to size and tire maker.
Old Sep 14, 2010 | 09:11 PM
JeepPuller's Avatar
JeepPuller
Well... I sold the 20's on craigslist and just purchased some 275/65R18XL (extra load) Nitto Terra Grapplers. These tires are not LT, but they have a load index of 120 which gives me 3089lb @50psi. Even accounting for the 10% reduction puts these tires at a better spot than the ones I had. My guess is these are very similar to a C load tire given the max 50psi. I'm sure the ride will change, but not as much as if I purchased the E load 10 ply ones. I'll take pics when they get in and then when they are on the truck.
Old Sep 19, 2010 | 06:31 AM
JeepPuller's Avatar
JeepPuller
Tires arrived Friday! Once my new tpms arrive I can mount them on the "new" 18s. My buddy is doing me a favor, so my truck has to site on 'blocks' in my garage while he takes the tires and wheels to be mounted. Hopefully before this week is out I'll have the new tires on and be looking to sell the Goodyear Wrangler SRAs.
Old Sep 19, 2010 | 06:40 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Lets see some pics! How much did you drop for the tires? Same size as stock, 32.2" tall?
Old Sep 19, 2010 | 04:49 PM
JeepPuller's Avatar
JeepPuller
I kept the same size dimensionally. I just dropped the wheel from 20 to 18. Pics soon I hope. I keep getting side tracked with other stuff when I'm in the garage.
Old Sep 21, 2010 | 12:10 PM
JeepPuller's Avatar
JeepPuller
Okay I took a few pics of the tires. I am excited to have these on my truck and end this 'project' to swap from 20s back to 18s. If my stems and tpms sensors would only show up I could complete this project.
Old Sep 25, 2010 | 08:33 PM
bronco429's Avatar
bronco429
Originally Posted by silver05fx4
im running 275-70-18 bfg's. and the ride isn't much stiffer than stock
if i knew you wanted 18s so bad i would try to work a deal with you since i would like a set of 20's
do you have a leveling kit with that size tire 275/70/18
Old Sep 30, 2010 | 08:17 AM
JeepPuller's Avatar
JeepPuller
My buddy is coming over tonight to pickup my wheels and tires. Hopefully by Friday evening I will have my new tires on and be done this 'project'.
Old Sep 30, 2010 | 09:17 AM
MCDavis's Avatar
MCDavis
Subscribing. Want to see your opinions on the Terra Grapplers.
Old Oct 3, 2010 | 10:59 PM
Mudd460's Avatar
Mudd460
Do you know how wide those wheels are?
Old Oct 4, 2010 | 08:33 AM
JeepPuller's Avatar
JeepPuller
Are you referring to the 'wrench' wheels? If so they are
Stock 18" wheel size
Width = 7.5
Diameter = 18"
Offset = 44mm (1.73228)
Number of bolts = 6
bolt pattern = 6 x 135
backspacking = 5.5"
I stayed with the stock size 275/65R18 and the tires are great so far. My buddy set them at 50 and they are kinda rough when the truck is not loaded, so I'll likely back them down to 45 unless I am towing/hauling. It is raining, so I'll wait until it clears to take and post some pics. I like the look of the tires too.
Old Oct 6, 2010 | 12:29 PM
JeepPuller's Avatar
JeepPuller
Overcast day and crappy blackberry equals fuzzy picture. Here is my truck with my 'new' Wrench wheels and Nitto Terra Grapplers in OEM size 275/65R18. The nittos are great! I just used my reset tool to clear the malfunction light and I'm back in business. I like the way this 'project' turned out.
Old Oct 6, 2010 | 12:56 PM
  #28
MCDavis's Avatar
MCDavis
Looks good!!
Frdtrtnv8
2009 - 2014 F150
61
Jan 28, 2016 08:36 AM
Vforce
2009 - 2014 F150
Jul 9, 2015 06:16 AM
MC5C
Dec 14, 2013 06:57 AM
bpevans
2009 - 2014 F150
Oct 22, 2013 05:54 PM
Tylus
Sep 9, 2011 09:26 AM
