Lowering a '76
Old Sep 2, 2010 | 09:13 PM
1967 Turbo 6.9's Avatar
1967 Turbo 6.9
One thing I saw people doing was turning the rear lower A arm bushing so it's
mounting surface is flat to the bottom of the frame. That bushing is slotted and that is Your caster adjustment. You want to keep them clocked so that slot is flat.
That in mind the mount is also offset so they ended up outside of the frame rails.
What I did was swap the bushings side to side that put them right under the frame rails.
I cut the mounting out of the Crown Vic frame and used some strap iron to fill the gap.
I still need to get under there and make it a little more eye a pealing.
Notice too that the motor mount ties the top of the frame rail to the cross member on the inside.
Nitnat
New Member Introductions
Jun 3, 2015 10:28 AM
frittingles
Apr 9, 2014 10:52 PM
F100wanted
Dec 12, 2013 09:27 PM
