Not working door handle fix
Old Oct 8, 2010 | 12:01 AM
TexasGuy001's Avatar
TexasGuy001
Do you have a link to how to do the swap to the older parts?
Old Oct 8, 2010 | 12:08 AM
LCAM-01XA's Avatar
LCAM-01XA
Nah, I did it on the driver-side door of a buddy's truck, but that's as far as my motivation went - his passenger-side door will likely never get converted, same with my passengers-side door as well (I got a '94 door on my bricknose cab, so I got the cable mess with it).
Old Jun 18, 2011 | 01:13 PM
bladez51's Avatar
bladez51
Update on the door handle repair
Just a quick note about the repair (see first post). It's been over a year since I did the "cable shortening mod" and I'm happy to say that it's still holding up!
Old Jun 21, 2011 | 06:44 AM
TexasGuy001
Good to hear that.
Old Jun 22, 2011 | 11:03 AM
yjzonie's Avatar
yjzonie
There are two other issue with the door mechanic. The sheet metal under the door handle pulls crack and break. They can be repaired by re welding the cracks and adding a reinforcement washer. The other fix for the cable is to bend the cable attachment tab out a little farther and adding a tach weld to keep it from bending again. Just my .02 cents as i've repaired four of these door issues.
Old Jun 22, 2011 | 12:00 PM
bladez51's Avatar
bladez51
Thanks for the tip. I do think that the attachment points are on the weak side and are probably flexing, which will invariably lead to breakage due to fatigue failure. I thought about bending parts and stuff, but I knew they'd bend back. Unfortunately I don't have the skill or tools to weld. Maybe I should try to obtain a welding outfit and learn to weld.
Old Sep 14, 2011 | 10:05 AM
wrenched's Avatar
wrenched
Great thread!
Wish I'd found before I spent so much time digging into my problem.
I too finally figured out that the inside door latch control just wasn't pulling the cable release far enough. I noticed on my mechanism that two of the riveted rotation points were worn which adds a fair amount of slop when the lever is pulled. I think this extra play is what caused my problem, but possibly some cable-stretch as well. All I did was to bend the tab (that anchors the plastic outer sheath retainer) away from the mechanism to effectively tighten up the inner cable, and now the door opens easily. From reading the posts, it looks as though I may be doing this again in the future if that tab bends back towards the mechanism.
96 F150 SC 4x4 5.0 Eddie Bauer
bladez51
Jul 2, 2011 10:13 PM
bladez51
20
Jun 25, 2011 07:26 PM
bladez51
Jun 8, 2011 06:26 PM
bladez51
42
May 18, 2011 12:49 PM
bladez51
21
May 24, 2010 05:53 PM
