Hydrolock???
Old Sep 2, 2010 | 08:36 AM
Stang5lgt's Avatar
Stang5lgt
So I woke up early and went out and tore down the truck. Started pulling glow plugs on passenger side (since it sounded like it was coming from that side) and tried turning the motor by hand each time I pulled one. Got to #5(I think) on Passenger side(3rd one back from the front) and squirt out comes oil. Pulled the injector and found a tore up o ring. So I am hoping that is my only problem.
Old Sep 2, 2010 | 10:01 AM
DieselOrings's Avatar
DieselOrings
SPONSOR
I would also suggest that you pull the valve pushrods from that cylinder and roll them over a piece of glass to see if they are bent. That knocking has to have come from somewhere.
I am sure that others will chime in with suggestions on other things to check. Hopefully, the piston rod did not get stressed too much.
__________________
Specializing in Viton® o-rings and leak repair kits for the 7.3L and 6.0L diesels
(970) 368-4455 aka guzzle
guzzle's Mods & Maintenance website
Old Sep 2, 2010 | 11:16 AM
SpringerPop's Avatar
SpringerPop
Since you have more than one injector out on that bank, you can measure where TDC occurs to determine if you've got a bent rod.
Pop
Old Sep 2, 2010 | 11:56 AM
Ponyboychris's Avatar
Ponyboychris
Pop
Good idea, Pop. I would have never thought of that.
Old Sep 2, 2010 | 03:06 PM
Stang5lgt's Avatar
Stang5lgt
Success!!! No bent rod or push rods. Truck purrs like a kitten again. Well as much as diesel can purr. LOL Thanks everyone for all the great ideas. That 7.3 is a tank. Just keeps pluggin away. International had o ring kit for me so I replaced all the o rings on it and the copper washer. So she is good to go!
Old Sep 2, 2010 | 04:56 PM
DieselOrings
SPONSOR
That is great news as it could have been a lot worse.
__________________
Old Sep 2, 2010 | 05:15 PM
farmdad's Avatar
farmdad
Great to hear that you got it fixed. Good job on the diagnosis and repair.
Pop, can't rep ya but great advice on the TDC.
Old Sep 2, 2010 | 09:55 PM
Kwikkordead's Avatar
Kwikkordead
I bet it will start a lot better now too.
Old Sep 2, 2010 | 10:33 PM
Ponyboychris
Thanks for posting back a follow up. That's great news.
Old Sep 3, 2010 | 12:33 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Great stuff here guys. Dan, you are the man, and yes I have to spread it around. It is nice to see a good diagnosis and relatively quick fix. Glad it went well this time.
Old Sep 3, 2010 | 12:32 PM
Stang5lgt's Avatar
Stang5lgt
So took it for a 100 mile drive this morning. Running great. Took about 10 miles to burn off the left over oil in the pipes. She is idling smoothly and making good power. I seems to be doing better on mileage too. I think that is thanks to the turbo I picked up that only had 30k on it for 275 bucks.
Old Sep 4, 2010 | 12:15 AM
Kwikkordead
Excellent!
mustangmatt
Jan 4, 2017 06:52 PM
terrymargate
6.7L Power Stroke Diesel
56
Jul 24, 2016 07:45 AM
53jimc
Jun 1, 2016 06:59 PM
akdriver
Sep 22, 2015 06:57 PM
Shake-N-Bake
28
Mar 7, 2010 10:19 PM
