wants to stall
why it cost me 1400.00
all eight plugs broke off (THANK YOU FORD!) one fell into cylinder so there went the alum head off and to shop. Labor got me @ 910.00, parts @ 490.00. And he only charged me for 13 hours of the 22.
As for the fuel filter thats a thought, but I just had the fuel pump replaced a few months ago @ another 900.00.
Wow! The fuel filter is a great place to start; symptom is in line with that and the work done to date. Also an easy DIY project for you.
If you are going to have someone do it then have them start with a full fuel pressure test including the flow testing and injector bleed down testing. That way you will know if that the fuel system is correct and the next step I would go with would be a compression test and cylinder bleed down test. Then we could look into the ignition system.
Oh crap, I forgot to ask. Do you have and check engine light codes? That could save us a lot of guessing.
No codes shown
davidmolina
1997-2006 Expedition & Navigator
07-30-2014 10:19 PM
Zed
06-12-2002 12:16 PM
