WW Install Question
Old Aug 30, 2010 | 06:47 PM
jcobb124's Avatar
jcobb124
WW Install Question
Alright, I really want to order a WW, but I am nervous about the install! Is it fairly easy? I would consider myself mechanically inclined, but I know nothing of diesels and turbos!! So let me have it, how is it??
Old Aug 30, 2010 | 07:06 PM
DieselOrings's Avatar
DieselOrings
SPONSOR
Not a bad job at all and there are plenty of write-ups on how to do it. Some with the turbo in the bay, others with it out. Personally, I would never consider trying to do it while it is still mounted.
It will be a little intimidating the first time, just take your time and remove one item at a time while pulling the turbo. Figure probably half a day the first time and make sure you have all the parts necessary to put it back together and have all your tools laid out ahead of time.
__________________
Specializing in Viton® o-rings and leak repair kits for the 7.3L and 6.0L diesels
(970) 368-4455 aka guzzle
guzzle's Mods & Maintenance website
F350-6's Avatar
F350-6
If you're mechanically inclined, you'll be fine. If you live in Lake Charles and like little bitty beers, wait for Rick to show up and he'll probably invite you over to his place and offer to help you with the install.
Old Aug 30, 2010 | 07:10 PM
Robert6401's Avatar
Robert6401
Hah! If you've never removed your turbo before, plan half a day for removal of the v-band clamp on the rear of the turbo at the baby's butt!!!
Seriously, hopefully your's will be easier to remove than mine was. I've heard that spraying it down with PB Blaster or something similar the day before will help break it loose. As for me, Chuck Norris had to get mine off!
Good luck!
Old Aug 30, 2010 | 07:17 PM
jcobb124's Avatar
jcobb124
Thanks guys for the input!! Now I just have to build up the kahunas to give it a shot!
Old Aug 30, 2010 | 07:30 PM
tigwelder's Avatar
tigwelder
not to bad a job.
this is my first diesl and had no ideal of how they worked.
i did alot of searches her and found some good pics.
it took the most of a day to do it and the foil deleate while i had the pipe off.
there is a tool list in a post on here you can search.
the hardest thing was to find a small 12 point socket to fit the turbo bolts.
i left the wastegate hooked up and moved the housing to the side.
fouled the exaust side with a tape wraped screwdriver and used a ratchet wrench to remove the wheel.
the worst part were the sore ribs that lasted a few days from laying over the front end.
Old Aug 30, 2010 | 07:36 PM
tdpower's Avatar
tdpower
Here is a good write-up: 99-03 Turbo Removal & Wicked Wheel Installation .: Articles
I would get the turbo o ring kit from Bob (Guzzle). Link in my signature. You might also look into the ebpv delete.
Old Aug 30, 2010 | 07:40 PM
megawatt00's Avatar
megawatt00
Easy beans man. Like Chris said Rick lives in Lake Charles and will walk you through it no problem at all.
Old Aug 30, 2010 | 07:58 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
That is also the perfect time to replace up pipe donuts, if needed.
Old Aug 30, 2010 | 08:01 PM
jcobb124's Avatar
jcobb124
Im gonna order the kit from RiffRaff, my AIH delete plug is already on the way from them. I am also thinking about maybe saving up a few extra bucks and go for the gusto and go with the Big Head Wastegate too!! I really dont know!
As always, gentlemen thanks for all the feedback and encouragement!! I ain't skeered! Its gonna be on, like Donkey Kong!!
Old Aug 30, 2010 | 08:07 PM
aawlberninf350
It's a Van Gogh
I also considered the Big Head and was advised for my application (towing a 5er, schlepping to work, running over Toyotas) it was pretty useless.
Also be careful with the screwdriver when removing the wheel; I used too skinny a blade and managed to dent the hot side wheel.
