popping noise
Old Aug 30, 2010 | 04:49 PM
Joe28443's Avatar
Joe28443
Joe28443
popping noise
I've got a popping noise coming from my front right corner when making turns and going over bumps. I've had a mechanic check it and she sees nothing wrong. My shocks are the stock ones that have been on it for 150k. I know I need some but would one going bad possibly make this noise or do they just sag when they are going bad?
Old Aug 30, 2010 | 06:21 PM
Technitom's Avatar
Technitom
Veteran: Navy
probably your front sway bar bushings... usually where they meet the frame. the rubber goes bad... pretty common
Old Aug 30, 2010 | 06:33 PM
Sheldon Plankton's Avatar
Sheldon Plankton
Ball joints. Very common problem.
Old Aug 30, 2010 | 06:49 PM
hammer65's Avatar
hammer65
X2 In sway bar bushings/
Old Aug 30, 2010 | 08:14 PM
Joe28443's Avatar
Joe28443
Joe28443
thanks thats got to be fixed soon! I hope its not the ball joints, they were just replaced!!! Thanks guys
Old Aug 30, 2010 | 10:38 PM
KC92F150's Avatar
KC92F150
Check out this link Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
Hope it helps
Old Aug 30, 2010 | 10:48 PM
big poppa's Avatar
big poppa
If you ball joints were done the guys got you on the right track. Those stock swaybar bushings are trash IMO, get the polyurethane and this place is where I got mine, great prices. Energy Suspension Parts: 2 Wheel Drive, Ford Excursion 2WD 2001
