Need some info on my problem
Old Aug 30, 2010 | 09:20 AM
idahodisco's Avatar
idahodisco
OK so I have had this strange short that will only happen in the morning when its cold out the truck wont start but I can hear it clicking.
What I have done is replaced all 30 wires and all new connections all of the wires are located behind the passenger side battery by the head light and that fixed it for about a month but know in order to start I have to bang on the round solenoid thing behind the batt? it has a few wires that connect to the two nuts???
I think its that thing can I bypass that I need to rule that thing out before I start to dig in deeper?
Old Aug 30, 2010 | 09:21 AM
rupejosh's Avatar
rupejosh
how do the battery cables look?bad cables or bad connections will cause this i just went through it so its fresh in my mind
Old Aug 30, 2010 | 09:33 AM
idahodisco's Avatar
idahodisco
They are good I did clean them up BUT on the passenger side the aluminum clamp on the positive side of the batt is a little lose where the red wire enters the batt clamp but I have wiggled that around and the truck still wont start only if I play with the Glow Plug Relay?
Old Aug 30, 2010 | 10:04 AM
greywynd's Avatar
greywynd
The relay on the passenger side inner fender is for the starter, not the glow plugs. It's a dual relay system on these trucks, both it and the one on the starter have to be working for the starter to get juice. Yes, you can bypass it using heavy jumper/booster cables, but make sure that you are aware it could turn the engine over regardless of the gear it's in, etc if you do this!!
Old Aug 30, 2010 | 10:15 AM
idahodisco's Avatar
idahodisco
I see so if its doing it again then I can just jump it and it will turn over do I need the key on or off?
Old Aug 30, 2010 | 10:41 AM
oreocreaming's Avatar
oreocreaming
ya, thats the first starter solenoid your banging on. its going out if you have to hit it. they are cheap enough to replace. and yes, you can jump it from one big post to the other. key on if you want it to fire, off if you just want to crank it. one thing im wondering about though, when it clicks that means it working. so, if its clicking and your still not firing then most likely its the second solenoid on the starter itself.
Old Aug 30, 2010 | 11:35 AM
87crewdually's Avatar
87crewdually
Just because it's clicking doesn't mean it's making contact inside. The contacts can burn causing the audible click with no start.
Put a meter, or atleast a test light, on the lugs and with the solinoid engaged (key in start position) you should have battery voltage at both (all three really) solinoid lugs.
Old Aug 30, 2010 | 08:10 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I will second that.
The solenoid clicking means the electro magnet is still working.
But that does not mean that the contacts have not been burnt or worn out.
Just replaced my glow plug relay last winter, still clicking but no power to the glow plugs.
That solenoid is about 25 dollars at any parts house.
Old Aug 31, 2010 | 04:58 PM
idahodisco's Avatar
idahodisco
Dang it was like $11.00 and it has started every time!!
I think I got it!
old broke prospector
Aug 9, 2013 12:26 PM
DeanBob
Jan 23, 2013 09:16 AM
atomicjoe23
46
Feb 27, 2009 07:58 PM
Thudpucker
Dec 19, 2002 10:35 AM
classicfordluvr
Mar 19, 2002 10:01 PM
