52 long bed
Old Aug 30, 2010 | 07:35 PM
52 Merc's Avatar
52 Merc
Somewhere during the course of 1950 production the bed style on the F-1 was revised as a running change from raised panel to flat side. In fact, the entire build design and structure is totally different between the two, the later version being much simpler and cheaper to build. If anyone has been able to narrow down a date, I'd be curious to know. AFAIK, the F-2/3 didn't change throughout it's model run, 48-52.
My question is; is the wheel hump area in the same place on the 8' beds between the 48-52 and the 53-56, which is what that repro bed appears to be based on? If one was to use that bed on an early truck, would the wheels end up in the right place?
Old Aug 30, 2010 | 08:36 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Interesting observation. The wheel base of the '48/'52 F-2/3s is 122" while the wheel base of the '53/'56 F-250s is 118". The charts in the respective dealer handbooks show the F-2/3 bed is 96.05" long while the F-250 bed is 96.0" long. The rear axle location on the F-2/3 is 47.79" back from the headboard while the F-250's is 46.96" back. Almost an inch difference, but how does the shorter wheelbase work with that? Not sure what all that means. Stu
Old Aug 30, 2010 | 09:45 PM
mtflat's Avatar
mtflat
Originally Posted by vintage tin
hey bob and stu,his bed has the raised panels on the side,would that not make it a 48-mid 50 express box?or did all the express boxes have the raised panels and just the f-1s did not have them.
mtflat, i have a extra set of running boards i get with my 50 merc m-68,they are not exactly like my boards but they are the same length.let me know if i can help you out with this.
Roy, I sent you a PM. Thanks!
Tim
Old Aug 30, 2010 | 10:14 PM
rodeojunky's Avatar
rodeojunky
Wow, You all are blowing my mind on all this knowledge that you have
Old Aug 30, 2010 | 10:33 PM
vintage tin's Avatar
vintage tin
yeah huh...these folks will do that to ya,and i think that is just the tip of the iceberg so to speak.
Old Aug 30, 2010 | 11:14 PM
51PanelMan's Avatar
51PanelMan
Here's a side shot of a 52 F3 that I had.
Here are some additonal pictures of a 48 F3 and a separate F2/F3 bed.
Sold the truck with the extra bed several years ago on eBay for about $900.
Old Aug 30, 2010 | 11:41 PM
bobj49f2's Avatar
bobj49f2
One difference I have noticed in the 8' Express box is some came with round wheel wells, some with oval wheel wells. The original box on my '49 had the round wells while the box I replaced it with had oval wells. The wells in the second box were hacked up so I cut the wells out of the '49 box and welded them into the replacement box. I don't know for sure when they changed the shape but I would guess it might have been around the time Ford changed the design of the F-1. It could also have been an assembly plant difference, I don't know, but it was like the ribs on the back of the '48-50 trucks, some had them, some didn't, I think it all depended on what plant the truck was assembled at.
Old Aug 30, 2010 | 11:47 PM
51PanelMan's Avatar
51PanelMan
I just thought of another thing along Bob's wheelwell difference. Does anyone know if Ford changed the location of the tailgate latches on the Express beds between the 48-50 and the 51-52 model years like they did on the F1s of the same years (i.e., in the upper roll vs below the upper roll)?
Old Aug 31, 2010 | 12:39 AM
bobj49f2's Avatar
bobj49f2
Ilya, all I can say about your tailgate question is I've had quite a few '48-52 F-2s and 3s and I've never noticed a difference. Not saying I could have missed it though.
Old Aug 31, 2010 | 08:35 AM
rodeojunky's Avatar
rodeojunky
That looks just like the one on my truck, except my head board has been modified with diamond plating and steel tie downs. Thank you for the pics.
52' fordnut
Aug 14, 2014 08:35 AM
Lwlandy
Mar 24, 2014 12:53 PM
outsource77
Aug 9, 2010 06:51 PM
david1951F1
May 24, 2005 09:26 PM
mich52
Dec 26, 2003 03:10 PM
