glowshift gauges installed ???
Old Aug 29, 2010 | 11:07 PM
frydaddy56's Avatar
frydaddy56
I just installed the 3 pod glowshift diesel package in my 1997 f250 the gauges seem to work properly the exhaust temp and the tranny temp and the boost ,Just how does the boost gauge work mine stays on 0 untill i get on the throttle then it moves up then back to 0 when i let off, at 60 miles an hour it reads 0 is this correct? thanks for your time exhaust 500-600 at 60, tranny temp runs 150 at 60, boost runs 0 at 60, what are everybody gauges running
Old Aug 30, 2010 | 05:13 AM
427 fordman's Avatar
427 fordman
That seems right, mine runs at 0 at 60 too. 75 I run about 2-3, depending on wind. As long as you get good boost numbers when you get after it I'd say it's right.
Old Aug 30, 2010 | 09:07 AM
Krisx125's Avatar
Krisx125
Hey, could you post a pic of the set up installed? Im going to order some but want to see what they look like first. thanks
Old Aug 30, 2010 | 11:04 AM
427 fordman
I'll try to remember to get one today. I'll be in my truck in a few hours...
Old Aug 30, 2010 | 03:38 PM
427 fordman
See if I can get the pics up...
showed a couple of different colors for ya. Not real clear pics, not bad, off my phone.
Old Aug 30, 2010 | 06:35 PM
bad12jr's Avatar
bad12jr
They look like good gauges but not to be doging them I've heard bad out of them from a few ppl around here. Could have been some problems with early ones idk?
Old Aug 30, 2010 | 07:21 PM
427 fordman
Ya I know some don't care for them but I've had no issues with them at all.
Old Aug 30, 2010 | 10:52 PM
Krisx125's Avatar
Krisx125
So does the pillar just screw over the factory pilar?
Old Aug 30, 2010 | 11:14 PM
jchosler's Avatar
jchosler
No it replaces it. I have re interior so I had to paint mine
427 Fordman, are yours glowshift?
Old Aug 31, 2010 | 03:05 AM
chicagodragon's Avatar
chicagodragon
my next gauge...
Old Aug 31, 2010 | 05:46 AM
427 fordman
Ya, they are glowshift. I have in my head the pillar went over the stock one, but my memory is sometimes, well, not real good, so I could be wrong.
Old Aug 31, 2010 | 08:46 AM
XBAJBUSX's Avatar
XBAJBUSX
what paint did you use ?was the egt hard to install ?
Old Aug 31, 2010 | 10:20 AM
jchosler's Avatar
jchosler
Maybe some do go over the stock one, mine didn't. I used a red paint for plastics that I found at the auto store, nothing complicated. The pyro was easyy if your good with a drill
Old Aug 31, 2010 | 10:49 AM
Brown Falcon's Avatar
Brown Falcon
Some of the pillar pods attach to the factory pillar but they are only large enough to cover the gauges. If you don't see a seam around the gauges it's probably a full replacement pillar.
Old Aug 31, 2010 | 11:08 AM
dougbrown's Avatar
dougbrown
Originally Posted by chicagodragon
my next gauge...
Nice! Where did you get that? How many gagues will it handle?
