track bar bracket broken
Old Aug 29, 2010 | 10:42 PM
mudmaker's Avatar
mudmaker
Has anyone had the upper track bar bracket (attached to the frame) break?
I have been working on the front end of my F350 and trying to get the steering and such tightened up only to find the track bar bracket is broken in half and the track bar is not really attached to anything on that end. I am assuming I can just replace it with a new bracket and be good to go.
What would cause this to break? Is there anything else I should be checking out?
Old Aug 29, 2010 | 11:10 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Are we talking OEM or aftermarket that came with a lift?
Old Aug 29, 2010 | 11:37 PM
mudmaker's Avatar
mudmaker
OEM, It is a cab and chassis
Old Aug 30, 2010 | 02:15 AM
blacksoot25's Avatar
blacksoot25
i havebroken that same bracket and the lower perch (on the other end of the track bar) before the onlything is mine was an aftermarket with the lift. i had to make one thicker on both ends and make sure my welds were good and tight. dont know why it happens in my case im not extreme with beeting on my truck
Old Sep 26, 2010 | 11:03 PM
mudmaker's Avatar
mudmaker
It took me a while, but I finally got the bracket ordered last week (thanks ED)and installed it today. What a difference having a solid track bar makes!!! Pretty easy swap. Now onto my dip stick issue, and while I was under there today I noticed my front seal is leaking Seems like every time I work on it my list of things to do gets something added to it. One of these days I will have everything taken care of on this truck!!LOL!
Old Sep 27, 2010 | 06:06 AM
derek0525's Avatar
derek0525
I have broke mine a couple times but it is an aftermarket one from superlift after the first time I broke it I got an adjustable track bar and welded the bracket back up ended up
Breaking 2 more times different spots it was kind of a crappy design got a Skyjacker bracket and it has a better design and is made with thicker metal.
Leeet
Oct 1, 2015 08:32 AM
ycis
May 22, 2014 11:56 PM
rpenterics
22
Apr 28, 2014 07:25 AM
Boss_hoss
Apr 4, 2011 04:03 PM
389sixpack
May 29, 2007 01:30 PM
