Cylinder one blown
Old Aug 29, 2010 | 09:33 PM
seaduction's Avatar
seaduction
Cylinder one blown
Anyone have similar problem? I have a 2006 Supercrew with 5.4, I have maintained this engine as required. The motor has 58,000 miles on it, I have not had any issues with the truck until last week. I had an exhaust leak that was evident for about a month, before I had it fixed. The mechanic ended up replacing the exhaust manifold (passenger side) due to it being warped. Other that the exhaust mainfold, the only other service was fog lamp bulb replacement. As I said, I have changed oil every 3000 miles, and recently started using synthetic.
The day I picked up the truck after the manifold was replaced, the truck was running as well as it ever has. I picked up my boat and was towing on the highway when I experienced the feeling as if I was driving over railroad tracks at 70 mph, at first I thought maybe I had a flat tire, or was driving on a bad section of road (if you live in Michigan you would understand that). Anyways, the shaking quit after 15 seconds or so, only to do it again in 15-20 seconds. I first did not realize I had a potential engine problem, but realized my truck seemed to be slowing down, I then looked @ the dash and noticed the check engine light flashing. Exited from the highway and truck nearly would not stop, brakes were to the floor, apparently loss of vacum causing poor braking. At the stop, the truck was sputtering and idling very rough (felt like it was going to stall.) Upon acceleration, truck was missing and continuing to sputter. Parked car for the weekend and took to mechanic who put it on computer, it read misfire cylinder one. There is no compression and appears I will have an expensive repair job. Unfortunately the 60K powertrain warranty was not in effect with my vehicle and I do not have an extended warranty. Since this happened immediately after exhaust manifold repair, could there be any corelation, I do trust the mechanic, but you never know? I am not mechanical at all and unfortunately rely on research and asking questions to learn as much as I can, but have never been mecanically inclined. Sorry, if this has been addressed in another thread, my questions are, could there be any connection to the previous repair under normal circumstances? Has anyone had this happen to them? If so, what was the cause? What was the fix? Seems very hard to believe that without any warning at all on such a well taken care of motor with few miles I can be faced with this type of issue. Thanks in advance for any help.
Old Aug 29, 2010 | 10:28 PM
dusty d's Avatar
dusty d
dude, sounds like you got some issues. i wouldn't think that your local mechanic replacing a manifold would zap your number 1 cylinder. there could be a million different reasons why your motor took a crap, and i doubt that the manifold has anything to do with it. if your mechanic is a stand up guy, he would have told you if he screwed anything up or not.
Old Aug 30, 2010 | 07:43 AM
EBTDM's Avatar
EBTDM
If you really trust your mechanic then trust him to do the right thing. Take it back to him and let him tell you what is wrong with your engine. If you have doubts then take it to a different mechanic and do not tell him about the exhaust gasket and hear what he has to say.
From your description, it sounds like it could be a head gasket. I would find it interesting and would like to see pictures if you sucked a valve or burned a piston. If that is the case, then make sure they show it to you (take the pictures then) when they pull the head.
Oh by the way, Welcome to the forum. (Both of you)
Old Aug 30, 2010 | 06:20 PM
abah's Avatar
abah
Before your exhaust manifold was replaced did you hear any unusual noises?
Old Aug 30, 2010 | 07:58 PM
seaduction's Avatar
seaduction
no nothing unusual
JMG1
Nov 13, 2013 03:33 AM
mike_pop
6.4L Power Stroke Diesel
26
Nov 5, 2013 05:43 PM
Chunkah
2004 - 2008 F150
16
Jul 14, 2013 02:12 PM
1957F100
Escape & Escape Hybrid
Sep 27, 2012 05:36 PM
dk_dk
Apr 13, 2010 01:05 PM
