The informatin center goes blank intermittently. There have been other threads about this, but none have come up with an answer and I'm hoping someone has actually found a cure that doesn't entail replacing the cluster at $300.00 for a reman. This is the basic display that only shows the odometer, temperature, cardinal compass point, and then says things like low fuel and door ajar.
It is not a problem with the backlite. That works fine. The actual odometer function continues to count while it is blank. It is not a cold solder joint on the display itself.
Can I get a junk yard cluster and just plug it in?
