Sponsored by: Real Truck
Front Mini-Leaf level kit specs
Old Aug 29, 2010 | 03:20 PM
Blujay96's Avatar
Blujay96
Does anyone have the specs for the front mini-leaf kit, or the shackle kit. I am a fabricator and could easily build my own set.
Old Aug 29, 2010 | 06:07 PM
maevans's Avatar
maevans
I have a set of mini on my truck. I can measure them and let you know tommorrow evening.
Old Aug 29, 2010 | 06:43 PM
Blujay96's Avatar
Blujay96
That would be great. When I am done I will make a drawing and post it. By the way how do you like them
Old Aug 30, 2010 | 04:14 PM
maevans's Avatar
maevans
Here are the dimensions off my Sanderson Welding 2 1/2" mini pac -
Width is 3" - same as the OEM leaf springs width.
From the top working down to the axle
#1- 13 1/4" long
#2- 11 1/2" long
#3- 9 3/8" long
#4- 7 3/8" long
#5- 6 3/8" long
all are 1/2" thick.
I have had them for about three years now with out any problems at all.
Hope this helps.
Old Aug 30, 2010 | 05:38 PM
Blujay96's Avatar
Blujay96
That is great. Do you happen to know what size hole is in them. I will have to look at mine to see if I can tell. Thanks again.
Old Aug 30, 2010 | 05:43 PM
Grumpy Moose's Avatar
Grumpy Moose
The centering bolts in the spring packs are 7/16"
Old Aug 30, 2010 | 06:34 PM
maevans's Avatar
maevans
Thanks
Old Sep 9, 2010 | 08:37 AM
Blujay96's Avatar
Blujay96
Can someone tell me if the hole in the top of the axle bracket is 7/16 also
Old Sep 9, 2010 | 12:01 PM
Grumpy Moose
No, it is bigger. there is a button head on the end of the centering bolt, similar to a bolt head that's been rounded off. I'd say it's probably 1/2", but don't hold me to that. I can measure one of my old bolts when I get home if I can find it in my junk bin.
Old Sep 9, 2010 | 01:12 PM
Blujay96's Avatar
Blujay96
That would be great, thanks
Old Sep 9, 2010 | 10:03 PM
Grumpy Moose
OK, I went a dug up the OEM bolt from my front spring pack and confirmed what I was beginning to suspect. The replacement bolt that came with my leveling kit was a 7/16-20 UNF, but the OEM bolt is in fact metric. The bolt is a 11mm X 1.5 by 43mm long. Of course the replacement will be longer to accomodate the height of the thicker spring pack you use. The button on the end of the bolt is 16mm dia by 8mm high (roughly 5/8 X 5/16).
Old Sep 10, 2010 | 06:09 AM
Blujay96's Avatar
Blujay96
Thank you very much
