DIR Flasher
Old Aug 29, 2010 | 01:18 PM
75250ranger's Avatar
75250ranger
DIR Flasher
I have a 1991 f-250 with a 460. On my wiring digram the oxygen sensor has a wire that says it goes to the DIR flasher. Anybody know what that is? where it goes? Im getting ready to transplant the motor into my 1975 f-250 and am trying to make sure i know where all the wiring goes to before i start. Thanks in advance.
After some searching i know what the dir flasher is. Could someone please explain to me why the oxygen sensor is tied into it?
Old Aug 29, 2010 | 01:35 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Ok, I'll bite! dir flasher?
Old Aug 29, 2010 | 01:40 PM
75250ranger
yep thats what the wiring diagram says. all my research shows this to be the directional or turn signal flasher. Why would an engineer hook an o2 sensor to the turn signal flasher? Somebody straighten me out!!!!
Old Aug 29, 2010 | 01:51 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Not seeing it!
So if your right turn signal starts blinking, your running either Rich or lean?(Joke)
I'll go as far as a shared ground location, but that's it!
Old Aug 29, 2010 | 02:34 PM
75250ranger
my wiring diagram is showing o2 sensor as having 4 wires let me see if i can post a pic of it .
Old Aug 29, 2010 | 02:43 PM
ymeski56's Avatar
ymeski56
Der Postmeister
That would make it a heated o2 sensor. Still going w/ a shared Ground connection. Notice the multiple grounds off the Battery NEG in the diagram I posted.
Old Aug 29, 2010 | 03:19 PM
75250ranger
i cant figure out how to get from paper to computer file.
purple/orange- Dir flasher
grey/lt blue-pin 29 computer HEGO
black- ground
orange-pin 49 computer HEGO ground as well as self test output, idle air bypass valve, map, maual lever position sensor, transmission, coolant temp sensor, air charge temp sensor, egr
i got the shared grounds, the o2 ground, the o2 signal input, still confused on dir flasher
Old Aug 29, 2010 | 07:09 PM
F150xlt's Avatar
F150xlt
Here's the schematic of the oxygen sensor for a 88. It appears the wiring is
similar to your 91. The 88 has no self test wire.
Bottom left corner shows the heated oxygen sensor.
On the 88 it uses a 3 wire sensor.
The output of the oxygen sensor goes to pin 29 of the computer.
In the schematic it's a Dark Green/Purple wire.
The ground for the oxygen sensor is the body of the sensor which screws
into the exhaust pipe bung. The ground for the heater circuit is a Black wire.
In your case the sensor has 2 ground wires. You can tie them together and
ground them.
The 12 volts for the heater element comes from the ignition switch.
When the ignition switch is in Run/On 12 volts passses thru the ignition switch and provides
12 volts to two circuits.
12 volts goes to Fuse #5 which is the Turn signal flasher.
12 volts also goes to a 20 gauge fusible link and then to the heating
element of the oxygen sensor via a Gray/Yellow wire.
Old Aug 29, 2010 | 09:22 PM
75250ranger
awesome so i just need to supply an ignition fused 12 volt source. Thanks a bunch. T
Old Aug 29, 2010 | 09:37 PM
F150xlt's Avatar
F150xlt
Yes a fused switched 12 volts is all you need. It appears in later years, Ford started to monitor the heating element circuit and would set a trouble code if there was a problem.
Flame Out
Electrical Systems/Wiring
Nov 22, 2016 10:17 PM
Montana250
Jun 3, 2013 06:40 AM
AndeyHall
Aug 19, 2010 08:37 AM
pacrewchief
Escape & Escape Hybrid
Dec 6, 2009 02:15 PM
carpe_diem
Jun 22, 2003 09:00 PM
