Fuel tank retainer ring
Old Aug 29, 2010 | 10:34 AM
ronjon95's Avatar
ronjon95
Ok I droped my tank to check the screen and it was completly clean. I was threading the retainer ring back on by tapping it to turn because it's such a tight fit. I checked the assembly to see when it getting held by the ring and then snap the ring broke. Has anyone ever had this issue or herd of it. It was hard to get it started on straight from the begining. Would this be a dealer part or can you get on aftermarket. It is holding the assembly tight I just wont be filling the tank full just about half way.
Old Aug 29, 2010 | 11:45 AM
tdpower's Avatar
tdpower
I looked at Ed's site in my sig and only see the the fuel tank listed. I would check with your dealer or Ed. Maybe someone on here has an extra one for you.
Old Aug 29, 2010 | 01:26 PM
kupaa's Avatar
kupaa
I know what you mean by getting the ring started, it took me about 10 min before it catched the threads on the tank.
Old Aug 29, 2010 | 07:39 PM
danskool's Avatar
danskool
Go Bills !
I went to parts guy ed's site.
www.partsguyed.com
Set up my OEM Automotive parts. Year/make/model/
Then typed in "retainer ring" in the search box.
Then two listing show up.
The bottom listing is your retaining nut. You can view illustration to see it.
It don't show up with a part number. I would just click Add to Cart.
Old Aug 29, 2010 | 07:50 PM
big poppa's Avatar
big poppa
I know with Guzzles mods and maintance pages your supposed to chalk mark a spot from the ring to the tank so you can properly align the cap but thats a little to late. Check or call around junk yards for a SD or EX, I'm sure if you find one you'll find a cap, most people don't run into the tanks much, good luck.
Old Aug 29, 2010 | 07:54 PM
F350-6's Avatar
F350-6
I think this is the first time I recall hearing of that breaking. What were you using to tighten the ring back up? A hammer and block of wood like many of us use?
Old Aug 29, 2010 | 07:59 PM
ronjon95's Avatar
ronjon95
A punch and hammer.
Old Aug 29, 2010 | 09:10 PM
megawatt00's Avatar
megawatt00
If you either leave it in the sun for a bit or put it in some hot water it will expand the ring and make it much easier to install it.
Old Aug 29, 2010 | 09:15 PM
ronjon95's Avatar
ronjon95
It was going on straight and then I just needed another full turn and it would have been tight. The thing is it took more to get it off that to but it back on. I just fell like it could have had a flaw on it in the begening. or it was built on a Friday.
Old Aug 29, 2010 | 09:40 PM
Sheldon Plankton's Avatar
Sheldon Plankton
You might try a PM to another forum member with the handle "oldwood". I know he has a parts truck or two. I bought a radiator fan from him.
Old Aug 29, 2010 | 09:43 PM
ronjon95's Avatar
ronjon95
Someone posted the parts guy web site he has them. They are less than $15.00 and there new so i'll just what when I do the mods in the tank and replace then.
ronjon95's Avatar
ronjon95
Thanks for the info.
uscgrad93
Nov 11, 2014 11:07 AM
r___r
Dec 16, 2013 10:45 PM
prettygooddeerhunter
21
Jan 13, 2011 05:02 PM
lilmick21602
1978 - 1996 Big Bronco
Apr 24, 2007 11:53 AM
