Offroad & 4x4
Impossible?
Old Aug 28, 2010 | 06:56 PM
scatgo's Avatar
scatgo
Impossible?
I just put a 12 inch lift springs in the rear of my truck and would like to know if there is any way I could run it with u joints and not switch over to a CV and still get a smooth ride. The back drive shaft is at about 15*.
Old Aug 28, 2010 | 09:08 PM
73 ford guy's Avatar
73 ford guy
No!
Well not impossible, but it would burn out the ujoint in no time at that angle
Run a cv rotate up rear diff as needed and read this and you'll understand
https://www.ford-trucks.com/forums/9...e-shaft-2.html
And the while your at it put in one of these
Old Aug 28, 2010 | 09:54 PM
scatgo's Avatar
scatgo
How dose this sound as a temporary fix. Drop the center bearing so much the front and rear drive shafts are almost in line.?
Old Aug 30, 2010 | 02:00 AM
hav24wheel's Avatar
hav24wheel
With any amount of lift u should drop the hanger bearing.
Old Aug 30, 2010 | 08:55 AM
scatgo's Avatar
scatgo
I am about to do that but I am not sure how much.
Old Aug 30, 2010 | 08:57 AM
scatgo's Avatar
scatgo
Originally Posted by 73 ford guy
No!
I do plan on setting things up the way you say but I need to get this done so I can use the truck now with it RWD. When I get the transfer case in I will get all the drive shafts done.
Old Sep 2, 2010 | 08:37 AM
alpha/omega's Avatar
alpha/omega
try this...
FIX IT RIGHT FIRST TIME!
Old Sep 2, 2010 | 04:59 PM
fatdan460's Avatar
fatdan460
Originally Posted by alpha/omega
FIX IT RIGHT THE FIRST TIME OR YOU WILL NEVER FIX IT BECAUSE PEOPLE ARE LAZY!
fixed it for you
Old Sep 2, 2010 | 07:21 PM
73 ford guy
try this...
FIX IT RIGHT THE FIRST TIME OR YOU WILL NEVER FIX IT BECAUSE PEOPLE ARE LAZY and DUMB!!!
Another tweak on the fix...
Old Sep 2, 2010 | 09:17 PM
scatgo's Avatar
scatgo
Easy people. I need the truck now. Cant wait to get the transfer case. I am going to have to set it up the way it is now so I can use the truck then set it up again when I get the TC and the funds for the drive shafts. A lazy person would not do this twice and a dumb person would not be able to figure a way around the problem.
Old Sep 2, 2010 | 09:42 PM
73 ford guy
Ok I'll help you one more time...
My driveshaft ran me around $800 including shaft,cv, diff yoke and mounting flange on t case. All parts were new and a combination of sealed spicer 1350's in cv and greaseable 1350 on diff to be able to push dirt and mud out. Not cheap buts it's exactly what I needed.
Now I was in a wrecker one day having mainly new superdutys and dodge stuff
when I found a mint 1350 cv driveshaft with a 1410 slip yoke laying on the ground. I ended up buying it for my bro who needed one for his truck on 49 iroks. Ended up getting for 100$ and it turned out to be a front shaft on a 99- early 2000ish superduty. Shaft was too long and had to be cut down but no big deal. I think this is probably your best bet. You'll have to figure out a mounting flange that works for your application unless the superduty one works for you
Myfreeford
54
Feb 15, 2019 04:33 PM
Truckin23
Oct 6, 2014 08:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
