replacing trans????help
Old Feb 17, 2003 | 02:54 PM
Rat wagon's Avatar
Rat wagon
Can I jes unbolt the trans mounts of my np 435, support it,
remove the cross member and shifter, then undue the trans to bellhousing bolts and then jes slide that baby out? then slide
my t-18 up in there? or is there more to it?
Old Feb 17, 2003 | 07:27 PM
Mike W's Avatar
Mike W
That sounds good to me if you are using a transmission jack. You might want to replace the clutch as long as you have it out.
Old Feb 17, 2003 | 11:50 PM
Rat wagon's Avatar
Rat wagon
thanks, glad to here that.
Old Feb 18, 2003 | 10:53 AM
tw's Avatar
tw
Do you have to remove the crossmember? I didnt, but mine was a 4x4. If you arent using a transmission jack, i hope you ate your wheaties. It can be benchpressed into place, but youll feel it in the morning.
Good luck
Tony Warren
Nebraska
Old Feb 18, 2003 | 01:45 PM
Rat wagon's Avatar
Rat wagon
Its a 2 wheeler, and having the cross memeber out really helps.
I almost got my t-18 stuck somehow when I was yanking it out through the engine bay becuase of the cross memeber
