View Poll Results: Select as close as possible.
Truck is used mainly for pulling on hwy, trans went out before 180K
15
10.79%
Truck is used as daily driver, trans went out before 180K
37
26.62%
Truck is used for pulling on hwy, trans has not gone out by 180K
25
17.99%
Truck is daily driver, trans has not gone out by 180K
62
44.60%
Voters: 139. You may not vote on this poll
When did your trans go out? How many miles? What do you use the truck for?
This is something I am just curious about and would like to see if there is a pattern to it at all.
It is hard to make up perfect poll questions to separate everyone. So in addition to voting please also post what your truck/excursion is mostly used for, the year of the truck, at what mileage the trans went out, and has the fluid ever been flushed or changed.
Also for you guys that haven't had a trans go out, same questions. What year is the truck, mileage, majority of the trucks use, and has fluid been changed flushed?
Like for my 03 7.3 X I would say I have 169K miles on original trans. Truck spent majority of its time on the highway pulling a TT. Fluid has never been flushed till 169K miles.
Thanks!
Thanks!
My transmission went out shortly after purchasing the truck in 2003. I purchased the truck with approximately 51000 miles and by 58000 miles the transmission was toast. I thoroughly believe the previous owner dogged this truck and traded it in after a fluid change. I had Ford and the dealership agree to split the cost with me and it only cost me approximately 850 to replace the transmission. I now have over 130000 on a remanned transmission with no problems. Just normal fluid and filter changes.
Rick that's not stupid, that's taking care of business. Prevention instead of cure.
My '03 tranny went out around 80k after doing mostly daily driving, (before I bought it at 60k). Since then it is used for chasing parts, heavy hauling and trailer towing. May sit a week or two at a time. Just turned over 100k.
Ok here's the deal. Purchased the EX w/ 133,000 on it. Assume it is the original Transmission. OASIS report says nothing about a Trans change.
Did full Flush, Oil change and added the 6.0 Cooler at 139,000 miles. Trans runs good but only have 1000 miles on the new oil. Used as DD and 25% towing teh Airstream.
I'm sure it's good to 200,000 +. (knock on wood!)
Same here on my current truck. My old '99 it went out with 55K on the clock as a daily driver, towing only occasionally.
