First Tow?
Old Aug 28, 2010 | 07:35 AM
n5926g's Avatar
n5926g
First Tow?
Good Morning guys,
I may have the opportunity to go South and pick up a Honda CRV.
The Little SUV runs,but needs tires,windshield,etc,and I have never driven it.
Im faced with the option of either having these things fixed down there(about 400 miles) and driving it back,or driving my 07 F-150 down,getting a car trailer,and bringing it back.
The "rub" here is my baby has the 4.2,and automatic. Shes got just over 45,000 on the clock.
I have towed before with my old 97(same powertrain),but am somewhat concerned about the load on the truck.
The trip is 99% interstate,and relatively flat.
Suggestions please!
Old Aug 28, 2010 | 11:57 AM
Coskid's Avatar
Coskid
No suggestions needed you should be OK to pull that car home. Just take it easy don't be in a rush to get anywhere and be nice to the pedal. If you have an O/D off switch make sure it is off and then go on your happy way.
I guess a suggestion I would make is if you are about to change your oil but its not quite time yet do it before you leave and have fresh oil for the trip home. Also check your other fluids, air filter, and any of the other routine stuff and you should be just fine.
Old Aug 28, 2010 | 06:14 PM
Oldguy4's Avatar
Oldguy4
ditto that. Are you going to use a trailer or one of those dollies that you just put the front wheels up on? That would be even easier to pull I think.
Old Aug 28, 2010 | 06:53 PM
n5926g's Avatar
n5926g
Probably will just make arrangements to get a U-Haul Car Hauler. The device your speaking of is a "tow dolley",and while Id like to use one,I dont trust the tires on the CRV,but I also dont want to buy some tires from a place thats 395 miles away.
Getting a warranty claim processed could be somewhat of a bitch......
Old Aug 28, 2010 | 07:32 PM
Coskid's Avatar
Coskid
You should be fine with no matter what trailer you use.
Old Aug 28, 2010 | 09:35 PM
Greg B's Avatar
Greg B
It'll do it especially with an open car hauler. If you get any bog or gear hunting at all keep it out of O/D.
Old Aug 29, 2010 | 09:21 AM
n5926g's Avatar
n5926g
Thanks guys for the replies,I like to baby my ride even if shes an XL.
Building_Fords
Oct 18, 2014 01:14 PM
BLUEOVAL1992
Feb 25, 2010 03:35 AM
biz4two
May 26, 2008 07:29 PM
toadx8u
33
Nov 13, 2007 04:08 PM
billb7984
1947 and Older Ford Trucks
Jan 5, 2003 08:45 PM
