Now What
Old Aug 28, 2010 | 01:05 AM
scatgo's Avatar
scatgo
Now What
I pulled the drums off today to inspect my brake and one side was covered in grease! It was all over the brake shoes and just about every where Else. I am thinking bearing seal but I have no clue on fixing this. Any diagrams and directions would be helpful.
Thanks
Chris
Old Aug 28, 2010 | 01:20 AM
740 Turbogreasel's Avatar
740 Turbogreasel
Once you undo the 8 bolts on the end of your axle, and slide that out of the tube(Gear oil may spill), you will find a giant locknut in there.
Get that off, and it is a fairly normal wheel bearing inside.
inspect both the seal, and the spindle it rides on to find cause of leak.
There is a special socket to buy, but you can work around that.
this is a Chevy, but its pretty much the same. http://www.askjeffwilliams.com/2009/04/
Old Aug 28, 2010 | 01:51 AM
scatgo's Avatar
scatgo
[quote=740 Turbogreasel;9267094]Once you undo the 8 bolts on the end of your axle, and slide that out of the tube(Gear oil may spill), you will find a giant locknut in there.
this is a Chevy, but its pretty much the same. 2009 April :: common car problems | car service manuals | online car owners manuals – Las Vegas Nevada 89109[/quote
Thanks Bro.....
Old Aug 28, 2010 | 08:15 AM
scatgo's Avatar
scatgo
Any one know where I can get the socket?
Old Aug 28, 2010 | 08:59 AM
plgebbia's Avatar
plgebbia
I believe most parts stores have them.
Old Aug 28, 2010 | 03:01 PM
95PSDieselP's Avatar
95PSDieselP
all i use man is a flay head screwdriver and a hammer just be carefull you dont bend it up or anything i just got doing mine too. but yeah dont waste the money with the socket man flad head and a hammer
Old Aug 28, 2010 | 06:14 PM
bad12jr's Avatar
bad12jr
Piece of pipe and four bolts. Weld the bolts to the pipe and grind them square . We made one when my seal went out. The one parts stores have are to big or to small. It still works great.
Old Aug 28, 2010 | 06:23 PM
bad12jr's Avatar
bad12jr
Oh yea and drill a hole for a big screw driver to go through
