THROTTLE BODY SPACER
Old Aug 27, 2010 | 11:27 PM
Dutter's Avatar
Dutter
Do they really work, has anyone tired them
Old Aug 27, 2010 | 11:42 PM
rikard's Avatar
rikard
Throttle spacers will give some improvement on some carb and TBI systems increasing the plenum area allowing better flow of the fuel air mixture. On a Multiport system they have no effect since the fuel is injected at the end of the plenum into the head.
Some produce a nasty whistle..
regards
rikard
Old Aug 27, 2010 | 11:54 PM
nflfreak43's Avatar
nflfreak43
waste of time and money to install one. unless it was a carb spacer....
Old Aug 27, 2010 | 11:59 PM
danger-ranger93's Avatar
danger-ranger93
not trying to hijack here but what about the spacers that go below the upper and lower intake?
Old Aug 28, 2010 | 12:03 AM
nflfreak43's Avatar
nflfreak43
still no good. the only reason the carb spacers work is it gives extra length for the fuel and air to mix.
the main reason people use those is to fit bigger valve covers on the engine, likely to clear 1.7 RR's mated with a big cam.
Old Aug 28, 2010 | 12:07 AM
danger-ranger93
well i'llprobably put one of those on anyway, just so i know its in the for when i go to 1.7's and taller or aftermarket valve covers
Old Aug 28, 2010 | 12:08 AM
Dutter's Avatar
Dutter
Alright then i definitely wont get one then,,lol,, Because mine is fuel injected,, Ill be selling some cheech and chong tickets for 200 - 300 bucks,, what mods can i do with that, I have full Intake and part of and exhaust, ow and its a 95 f150 5.0
Old Aug 28, 2010 | 12:11 AM
nflfreak43's Avatar
nflfreak43
cam or if you can somehow find some GT40 heads for cheap...
GT40 heads are what i'd do first, they are hard to find though, took me 6 months to find some at a decent price, $250..... most people think they are gold, and in someways they are for mild engine builds...
Old Aug 28, 2010 | 12:14 AM
danger-ranger93
i found a set of the cast iorn ones on craigslist for 200 or 250 but i didnt have the cash at the time
i was pissed cause i had JUST put some 110 bucks in my exaust and i had to also make a insurance payment
Old Aug 28, 2010 | 12:16 AM
Dutter's Avatar
Dutter
alright cool,, the only problem is im in CA and we have that stupid smog *****, will that affect it at all
Old Aug 28, 2010 | 12:19 AM
nflfreak43's Avatar
nflfreak43
yep.... GT40 heads dont have the smog hook ups in the back of the heads.... not sure if that will cause you to fail or not...
honestly in CA you are extremely limited....
Old Aug 28, 2010 | 12:28 AM
Dutter's Avatar
Dutter
yeah no kidding, its stupid because ill put on these mods on and tweek the motor, then come somg time ill change it to stock, then right after ill put it all back on
Old Aug 28, 2010 | 12:59 AM
86F150302's Avatar
86F150302
Phenolic intake spacers do work.
TB spacers... Do not.
Since when do gt40s not have thermactor ports in the back?
GT40P heads do not.
"air is sent into the heads only briefly on cold start up, so not having it there causes no real issues other than the visual pass."
BTW here are some GT40 heads and lower intake forsale.
As you can see they DO have thermactor ports
http://www.nloc.net/classifieds/show...ct/16794/cat/3
Old Aug 28, 2010 | 04:40 AM
TexasGuy001's Avatar
TexasGuy001
I'm really considering going with these heads. I have heard alot of positive comments about them.
http://thumperoforangepark.com/
Old Aug 28, 2010 | 05:14 AM
lew52's Avatar
lew52
...The intake spacers work very well , some use them for more clearence , but the main reason is they keep the upper intake cooler , the spacer stops the heat transfer from the motor & lower intake...Lew
