Sponsored by: Real Truck
need ur opinion
Old Aug 27, 2010 | 09:31 PM
Mike F250 SD's Avatar
Mike F250 SD
need ur opinion
What tire pressure should I run in the sand? See sig for details on truck. Thanks for input!
Old Aug 28, 2010 | 06:11 AM
spinella's Avatar
spinella
depends on how loose the sand is. try 20 psi...if it feels like your truck is working too much, then go down 2-3psi more. i tow my 9000lbs camper on the beach and i usually run about 15psi. if you are going to be doing this often then i would reccomend you buy a set of these. they work great. Tire Deflator - tyre deflators
Old Aug 28, 2010 | 09:28 AM
Mike F250 SD
Na just on vacation I was using about 30 felt like too much.. Thanks
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
