changing rear end gears
Old Aug 27, 2010 | 09:06 PM
xc4jokestomper's Avatar
xc4jokestomper
i currently have a 3.55 ls in my truck. im thinking about 4.10's. would i have ot change out the whole rear end or could i get just the gears and change them out? how hard is it to change the gears in your truck?
thanks guys
Old Aug 27, 2010 | 09:09 PM
jplinville's Avatar
jplinville
It would be easier and cheaper to find a used axle already geared.
Old Aug 27, 2010 | 09:39 PM
xc4jokestomper
well ive got a friend with a rear end with the 4.10 and hes wanting 500 for it. ive foun the actual gears alot cheaper. thats why i was asking. how hard is it to just change the gears?
Old Aug 28, 2010 | 04:44 AM
TexasGuy001's Avatar
TexasGuy001
The gears may be cheaper, but when you reassemble it you will want to replace all the bearings etc, since it is opened up.
Old Aug 28, 2010 | 05:22 AM
lew52's Avatar
lew52
Putting in a used rear end you get what you get , if you put gears in it you will want to get a full bearing & seal kit , check the axles real good & replace if nessary , you can also upgade to a good LS , this should be done by a profesional , more money but when your done its like a new rear end ....Lew
Old Aug 28, 2010 | 07:43 AM
vochy's Avatar
vochy
I would start checking around local junk yards. See if you can find what you want. If not, its not entirly difficult to take a rear diff apart. the most difficult part is shiming it. I would have a pro do that part. I am thinking about changing out the gears in my truck but it will be really expensive to do both the front and the rear at the same time ($800ish). I was really wanting to do 4.56 but i don't think i will find that in a stock truck at a junk yard.
Old Aug 28, 2010 | 09:48 AM
SAF's Avatar
SAF
Changing the gears should run less than $500 including parts at most reputable shops, much easier than changing the whole axle If its a 4x4 you MUST do both sets at the same time or lose the use of four wheel drive til you do...
Sam
